Registered 1971 K5
Can you ID this?
Since Im using new bedsides on my Blazer I decided to cut off some good sections that were left from my old originals. I figured I could use them for any future patchings. I also didnt feel right taking them to the scrap yard. As I took them apart I found this on the Passenger side skin. I was wondering what it was used for and if it was original to start with. My driver side skin did not have this. The outer section you see is a rubber hose 1/4 x 6" on a solid rod. Was this a support of some kind?
Member #1049
Re: Can you ID this?
I looks like the backing plate to the optional swing away spare tire carrier upper bracket
![]() Join Date: Jan 2000
yep, x2
70 Jimmy 4x4 71 GMC 2500 Too bad stupidity isn't painful |
![]() Join Date: Apr 2010
x3 the tube is so you can drop it down the tail light and hold it in place good piece to hold on to theres a need for it
!972 K5 Blazer,Highlander,A/C a twin to the one I Had 1972 K/5 Blazer ![]() 2003 Silverado Crew 2500HD (Daily driver) 1997 Ford focus (Beater) 2003 ford Taurus (student) 2014 Ford Fusion HYB (wife) 2003 Jetta ( Student) |
SKINNY TIRES RULE!
X4
Those can be hard to come by. Don't trash it.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
go cyclones
cool, I love "what is this" post so informative.
Registered 1971 K5
Im not quite sure what you mean. It all looks like one piece. Is it supposed to come off, I thought it was welded to the skin. Im considering putting in the for sale section. If its something someone would need, I absolutely have no need for it.
If there are hole on the outside of the box side, then X 5. $25 shipped to WA ?
SKINNY TIRES RULE!
Shouldn't be welded on. Probably "rusted" on. Tap it with a hammer and it should break free. If the holes in the body skin where filled, someone may have welded it on when filling them.
They often are not removed from inside the bed wall when people remove the swing-away. They tend to fit tight and not fall out. They are hard to reproduce because they bend in two directions to match the bed wall and mounting a swing-away without one doesn't work very well. When it had a swing away, there whould have been another similar one on the bottom without the rod welded to it.
Registered 1971 K5
It makes sence now. I tried breaking it loose but you can see were the holes were a tad spot welded. I checked the lower bottom skin and the plate is missing. You can also see were it had the holes covered. When I get some time I'll mess with it and try and save it. Hopefully I can save the threads. I'll post new pics and I'll post a "what's it worth".
Thread Tools | |
Display Modes | |
