Old 07-17-2012, 05:26 AM   #1
Nat Steeves
1970 rear spring change
has anyone change 1970 stile truck over to leaf springs?
Nat Steeves is offline   Reply With Quote
Old 07-21-2012, 09:43 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 1970 rear spring change
Welcome to the board?
Do you mean change from "coil springs" to "leaf springs"?
Keith
Convert to disc brakes.
Old 07-22-2012, 06:44 PM   #3
dennislbrooks
dennislbrooks's Avatar
There are a lot of post on this and with a 2wd frame like I had, heer is what I did to make my 2wd coil to rear leaf springs using the 2wd frame which is bowed out at the wheelwells. Probably most oem rear spring trucks had a parallel/straight frame at the rear spring perch locations.
If this truck is to remain a 2wd, may not be worth the effort.
Front rear suspension mounts on the c10 frame must be notched 1 1/8" and add a 1/2" plate spacer for rear rear hanger
69 4wd suspension mounts however I do believe I could use slghtly modified 73-87. I had a donor 69 k10 rolling chassis.
1972 k10 leaf spring with one of the 3 leaves removed
1975 k10 rear 5 leaf 52 inch springs with overload adding a 2 1/2" lift block -- must be off centered about an inch
1987 np208 behind my 350 turbo
1988 Blazer GM 10 bolt front diff
4wd power steering gear -- i used a 1969 --- others will work
My stock 67 rear diff with perches flipped to top -- i ran rear disc on my c10.
Front sway bar 1 1/4" from a 1987 k10.
dennislbrooks is offline   Reply With Quote
Thread Tools
Display Modes
