Old 07-17-2012, 08:19 PM   #1
rbuckin111
rbuckin111's Avatar
230 Rebuild Pics
Here are a couple of pics of my rebuilt 230 that I put in my 64 GMC. It started up well and we broke it in right. Have put about 120 miles on in city traffic. Today, coming home I turned a corner and it stalled. When I started it up, it ran so rough it would hardly move. Any suggestions what I need to check out?
Attachment 957849
Attachment 957850
Lovin' my 64 GMC Fleetside Daily Driver
rbuckin111 is offline   Reply With Quote
Old 07-17-2012, 09:04 PM   #2
MikeS.
MikeS.'s Avatar
Re: 230 Rebuild Pics
Your attachments aren't working.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 07-17-2012, 10:25 PM   #3
corvettejim1968
corvettejim1968's Avatar
try an IMG from photobucket its free
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 07-17-2012, 10:38 PM   #4
MikeS.
MikeS.'s Avatar
Better yet host them here for free.
Past Master
Old 07-17-2012, 10:55 PM   #5
rbuckin111
rbuckin111's Avatar
Sorry guys, in my preview they showed up fine. Let's try this.
Old 07-18-2012, 05:38 AM   #6
old cruiser
old cruiser's Avatar
I,d check the tension of your manifold bolts, these will come loose when warmed up after new gasket put on. Also try a quality manifold gasket, the ones in rebuild kits are usually crap. hope this helps
old cruiser is offline   Reply With Quote
Old 07-18-2012, 05:51 AM   #7
T2vigil
T2vigil's Avatar
Could be going around a corner disloged something in the fuel tank and it choked up a line or your filter. disconnect the the fuel line from the pump and force some air back into the tank. Iv'e been there and done that.
T2vigil is offline   Reply With Quote
Old 07-18-2012, 08:57 AM   #8
1963c-10
1963c-10's Avatar
Id start w/fuel system. Check filter first and make sure to put a filter before the fuel pump also to keep trash out of it.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-19-2012, 09:10 AM   #9
rbuckin111
rbuckin111's Avatar
Ok, seems I found the problem, or at least one of the problems. I have a broken exhaust valve spring in the number 2 cylinder. Any ideas how one breaks a spring? Should I be looking for some other problem that caused the spring to break? Appreciate any suggestions you guys can give me.
Thread Tools
Display Modes
