Old 07-17-2012, 10:51 PM   #1
mattpiotr
Buying A Used Cam Shaft
My neighbor who builds race cars all his life built him self a really nice built up small block 327 to put in the Malibu to go down the quarter mile. he ran the car once and changed the oil......took it down the quarter mile once and tore the top end of the motor apart. he is putting a bigger cam in it. he is trying to sell me the cam that was in it. its a comp cam .454 lift with 268 duration. the lifters where all market when they came out. ive been wanting to do a top end rebuild on my motor for a while he told me he'd sell me the cam and lifters for $100 and help me install it i was wondering if it is worth it? i know that nothing is wrong with it. the only reason he went with a bigger cam was for more top and power......would i be getting a good deal here? he has all the paper work and everything it says $225 new with lifters.
mattpiotr is offline   Reply With Quote
Old 07-17-2012, 11:07 PM   #2
WarBeard
WarBeard's Avatar
Re: Buying A Used Cam Shaft
Heck yeah if the history is correct I'd buy it.
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 07-17-2012, 11:10 PM   #3
rwhit57
rwhit57's Avatar
If that cam will work for you. I think it's a good deal. His labor alone to help you do it is worth the 100. Break in on cams today is critical, due to the fact that oils no longer have a Zinc additive. Be sure he did this and I would do it again once it's in your motor. Dont know if it would matter but cant hurt.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 07-17-2012, 11:13 PM   #4
mattpiotr
OH i know its correct lo. i helped him install it and pull it out and put the new one in. when he removed it, it was sprayed with wd40 wrapped in newspaper and put back in the original box. the car was only ran wide open once, and idled to get off and on the trailer. i was a little hesitant about buying it because i heard horror stories but since i know the history of this one i should be alright.
Old 07-17-2012, 11:14 PM   #5
mattpiotr
Yes he did break it in. he uses all Amsoil Products. he is selling me 6 quarts of amsoil motor oil with that high Zinc.
Old 07-17-2012, 11:16 PM   #6
mattpiotr
Also when doing a top end rebuild i was planning on getting my heads rebuilt and painted. i ordered new comp springs for to match with the Cam. my buddy that is rebuilding the heads(same guy im getting cam from) said he would put new guides and the springs in. should i maybe look into getting new rods and rockers?
Old 07-18-2012, 02:35 AM   #7
INSIDIOUS '86
INSIDIOUS '86's Avatar
Yah go for it. Lube up the cam but make sure its clean first. Run it like your breaking it in again and you should be fine.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-18-2012, 07:43 AM   #8
BigBlocksRule
I've seen this done with mixed results. Some work fine, some flatten the lobes in nothing flat. You're assuming that all the lifter bores are identical in both blocks when they rarely are.
BigBlocksRule is offline   Reply With Quote
Old 07-18-2012, 08:17 AM   #9
RandyP
Getting Old; Going Broke
RandyP's Avatar
You getting the cam and the lifters? I'm not a mechanic by any means, but was always taught to replace the lifters when replacing the cam and if going back with the same cam and lifters to make sure you put them back where they came out.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Thread Tools
Display Modes
