Old 07-22-2012, 12:22 AM   #1
c10seconds
c10seconds's Avatar
Please help me ID this cam
Custom grind 3 bolt comp cam for LS motors
c10seconds is offline   Reply With Quote
Old 07-22-2012, 05:34 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Please help me ID this cam
Where's the third bolt? Looks like 2bolt to me.
I can only find one cam when I look for that grind #. I can't promise this is exactly what you have, but its the only 3727r/3733r cam I found.
Serial # A 6725 Spec Card# 047220
Part # 54-000-11 CAMSHAFT, LS1 CHEVY LS1/GEN III '97-UP
Core C54-11H CAMSHAFT BLANK, LS1 1997 UP 5.7 CORVETTE
Grind # LS1 3727R /3733R HR113+4
DURATION @ .050 INTAKE 234 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 246 INTAKE 1.70
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3520 EXHAUST 1.70
VALVE LIFT INTAKE .598 LOBE LIFT EXHAUST .3610
VALVE LIFT EXHAUST .613 LOBE SEPARATION 113.0
DURATION .006 INTAKE C/L 109.0
TAPPET LIFT INTAKE 283 CAM ADVANCE 4
TAPPET LIFT EXHAUST 295 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 8 JOURNAL DIAMETER STD 2.165
VALVE OPEN EXHAUST 60 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 46 DEPARTMENT P
VALVE CLOSED EXHAUST 6 SPC INSTR FOR CUSTOMER
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-22-2012, 06:15 PM   #3
c10seconds
c10seconds's Avatar
Thanks BR3W.. Its been a while since I put this cam in and I cant seem to find the spec card. Looking to get a nice converter built for the cam. The pic is the rear end of the cam/block. I may just have to call comp
Thread Tools
Display Modes
