Old 07-23-2012, 04:21 PM   #1
Midgets50
Midgets50's Avatar
Doors for my 51 truck
Hello all,
ive got a 51 3600 chevy truck and im getting down to needing doors to finish the build before it goes to be wired and painted. is it easier to try and find some cheap doors or should i try and repair mine. current doors have bottom rusted out and everything is froze up. missing window cranks and all internal parts. would it be easier to have a solid window instead of a wing vent in my current doors?
Thanks in advance
Midgets50 is offline   Reply With Quote
Old 07-24-2012, 01:53 AM   #2
parkwood
parkwood's Avatar
Re: Doors for my 51 truck
The only advice i can give you about getting new doors, is if your doors fit the opening nice, meaning does it open and close nice, are door gaps ok i would say use your doors. Getting door from another truck you take the chance of them not fitting as nice and could use more work in the long run.. If you doors are not rusted out to where they can't be fixed all the stuff you said was bad can be fixed..
parkwood is offline   Reply With Quote
Old 07-24-2012, 11:55 AM   #3
mr48chev
mr48chev's Avatar
The going price for a rust free door in fair condition around here is usually 75.00 although some sellers seem to ask a lot more.
I'd have to weigh the cost of patch panels and possibly paying someone to to the repair to the cost of a good door that only needed sanding and slicking out.
Also you have to look at where the doors are rusted out. It it is around where the hinges mount I'd change them.
mr48chev is online now   Reply With Quote
Old 07-24-2012, 07:52 PM   #4
Midgets50
Midgets50's Avatar
Thanks for the advice. if i was going to redo the current doors i have is there any special way to take them apart or at least the inside door panel so i can get a good clean before i put it back together. im actually taking a trip to washington in august i might have to hunt through clist and see what i can find and bring'm back with me
Old 07-25-2012, 10:12 AM   #5
mr48chev
mr48chev's Avatar
There isn't really much of a way you can take them very far apart to clean the insides.
Thread Tools
Display Modes
