Need part number (steering)
Hello truck lovers
![]() Can any one tell me the steering part number in the picture below: ![]() My truck is a 69 C-30 2WD. Thank You.. ![]() |
Re: Need part number (steering)
Check with The Truck Shop in Orange CA. http://www.truckandcarshop.com They have those. I just bought one in April for my manual gear. That is called the rag joint or steering coupler.
1987 R10 Pump Gas 496/TH375 Best 1/4 pass to date 60' 1.49 1/4 10.93 MPH 120 |
redsled87
Thank you for the quick replay ![]() Further, is this the part that you are referring to: http://www.summitracing.com/parts/OER-C2553/ |
#4 | |
It's Better With Nitro
http://www.classicperform.com/6092chevtrk.htm#44 ...but most of the other vendors, Early Classics, Brothers, etc. carry steering rag joints...enter "rag joint" as your parts search.
vin63
Thank you for your suggestion, Also, can you help me figuring the best size for a 69 Chevy truck? Thanks |
You'll need to confirm the spline count on the steering box input shaft and the corresponding size of the steering shaft. If this post was a few weeks earlier, I could've checked for you in person since I was in Chester, Il to visit in-laws.
Thread Tools | |
Display Modes | |
