Old 05-21-2003, 12:47 AM   #1
Castiron9
72 LONGHORN OWNER
Castiron9's Avatar
Exhaust manifold bolts question
Working on pulling the B.B. out of the Longhorn for the rebuild.Any suggestions on taking manifold bolts off....Just brute force and and a few banged up knuckles?????????Have sprayed bolts with the usual stuff...Also it seems that I can't get the 1/2 in deep socket in,,and 9/16 is to big...Any suggestions would be appreciated...So far I have everything almost off just these D &*^%$$#m bolts..........
72-SUPER CHEYENNE/20 LONGHORN
70-C/30 DUALLY
Castiron9 is offline   Reply With Quote
Old 05-21-2003, 07:24 AM   #2
JimKshortstep4x4
Talking
If you can't get them out by driving a socket on them, use a cut off wheel and cut the heads off. Pull the manifold off and remove the "studs" with a vise grip. It can be a real time consuming problem!
Good luck!
Jim
Old 05-21-2003, 08:07 AM   #3
TROYLV
exhaust
try a metric socket. between 1/2 and 9/16 i think is a 13 mm. ive had good luck doing that when bolts and nuts were rusted.
troy wilson
TROYLV is offline   Reply With Quote
Thread Tools
Display Modes
