08-04-2012, 05:01 PM | #1 |
Where is this leak splatter coming from?
Ok. Just did my radiator flush and put a 180* stay since it did not have one. During the 6 hour process at idle to flushing my coolant system these leaks occurred. Where is it coming from? Anyone experienced these leaks before because I can't pin point it. I hope it's not the block itself. It is leaking when the motor is running...
- 1967 Chevrolet C/10 SWB fleetside (New Project). - 1969 Chevrolet C/10 SWB fleetside (SOLD) - 2000 Ford Mustang 232 (DD) - 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver) Last edited by CEE1NG_RED; 08-04-2012 at 05:16 PM. |
08-04-2012, 05:06 PM | #2 |
Re: Where is this leak splatter coming from?
More...
I know one of the problem is the valve cover gasket needs to be changed, but I have no clue where the front leak is coming from? Should I change my PCV and breather as well to minimize pressure??
- 1967 Chevrolet C/10 SWB fleetside (New Project). - 1969 Chevrolet C/10 SWB fleetside (SOLD) - 2000 Ford Mustang 232 (DD) - 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver) |
08-04-2012, 06:46 PM | #3 |
what year truck/engine? Asking to determine if you have a clsoed pcv system. Not sure if you're asking about oil leaks or anti-freeze leaks, or both. Anyway - the oil on the frame in the locations you're talking about could be a few things -
1) if not a closed pcv system (i.e. older engines, etc - like my 66's) then it could very well be oil vapor that comes out of the oil filler tube breather that gets splattered by the fan. Take a peak around the firewall near the master cylinder - that's another common place for it to accumulate when you're driving - it gets blown back on the driver side firewall by the fan. or 2) could be a front main seal leak in the timing cover. But that doesn't normally "spreak" by the fan "that" much - but it can a little. I'm guessing you have a closed pcv system (i.e. a pcv valve and valve cover oil fill hole) but mentioned #1 just in case. Might look by the timing cover. I couldn't really see what you were talking about on the rear side(s) in the pics, hard to tell against a black block. Valve cover leaks can be decieving - that gunk gets everywhere, but seems like it's more than could possibly leak from a vc. Anyhoo. When re-installing, I only put RTV on the valve cover side of the gasket, none on the head side, and just barely tighten them down. Most overtighten them, including me. |
08-05-2012, 04:02 PM | #4 |
...it's a '78 350 small block. I'm thinking the front may be a main seal and rear a valve cover gasket and pressure screw valve behind the top of the motor. I'll prolly just have the while engine done with new seals and gaskets by a mechanic. I have Ni work space to lay down the parts and my city does not condone to working in the driveway. :/
Thread Tools | |
Display Modes | |
