08-08-2012, 11:18 AM | #1 |
Brake problem...frustrated
helping my buddy...
It's a 1970 K20, v8, drum brakes, power booster was installed 15 years ago. Booster replaced by mechanic recently after new shoes, cylinders, MC, and brake lines. Truck stopped well after brake work a month ago, but now acts like it doesn't even have "power" brakes....must press very hard to stop. Brought back to mechanic but he can't seem to be able to fix. He re-adjusted brakes and was good for a short while, but now is hard to stop again and if you press hard enough, brake light comes on! Took drums off, linings look good. Any suggestions? Thanks |
08-08-2012, 01:44 PM | #2 | |
Active Member
Re: Brake problem...frustrated
If the rear brakes are doing most of the stopping, it will be very hard to stop. The MC has two pistons, one for the front brakes and one for the rear brakes. If the piston for the front brakes is bad your braking primarily with the rear brakes.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
08-08-2012, 01:50 PM | #3 |
hard peddle sounds like brake booster , or booster not getting proper vacuum...
08-08-2012, 02:09 PM | #4 |
How do I check if booster is getting proper vacuum? Could it be that the pushrod is just to short?
08-08-2012, 02:41 PM | #5 | |
I have had poor luck with rebuilt boosters. I installed a rebuilt unit last August and it was bad from the start. I returned it and the replacement worked well until about two months ago, then it also failed. I replaced it under warranty and so far it has been OK. |
08-08-2012, 02:47 PM | #6 | |
Good point. He bought the booster from brothers, I think it was new??? Posted via Mobile Device |
08-08-2012, 08:54 PM | #7 |
Just a car guy
Vacuum us the first thing I'd check.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
08-08-2012, 09:46 PM | #8 |
Kinda curious about that brake light coming on. That should really
never happen. It indicates that one system (front or back) has essentially failed. Booster problems shouldn't cause that. I'm thinking bad m/c. One simple test for booster fumctionality: with the motor off, pump up your pedal til firm and hold. Start the motor. If pedal moves toward the floor, your booster is working. If not, its dead. Posted via Mobile Device |
08-09-2012, 02:07 AM | #9 |
Possible .....air in the lines
1965 c10 short stepside (dad's project) 1967 c10 fleetside 350/350 trans (my baby) |
08-09-2012, 09:35 AM | #10 |
08-09-2012, 12:35 PM | #11 |
08-09-2012, 01:11 PM | #12 |
at idle it should be around 16 inches and hold steady at that...not swing back and forth ....did you try the break peddle test that silkside described ....that will tell you alot.....
08-09-2012, 01:48 PM | #13 | |
Thanks Posted via Mobile Device |
08-09-2012, 02:04 PM | #14 |
Project Junkie! Fishing Poor!!
The brake light that came on indicates that you have air in the proportioning valve somehow. If the master cylinder had a bubble stuck somewhere it could have come free and worked its way to the propertioning valve. I would rebleed the system and see if that fixes it. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
08-09-2012, 02:11 PM | #15 |
Should I rebleed each wheel or just bleed prop block by cracking each fitting while holding pedal down.
Posted via Mobile Device Last edited by airbrushguy; 08-09-2012 at 02:28 PM. |
08-09-2012, 03:00 PM | #16 |
Just a car guy
Bleed at the wheel starting with the right rear, then left rear, right front, left front.
08-09-2012, 04:39 PM | #17 |
doing the booster test should tell you that the booster is ok,like others said try bleeding all the wheels again and see if that helps....when you drive it do you have to pump the brakes to get a peddle?...or is it hard the first time you hit the brakes....how long does the brake light on the dash stay on when you hit the brakes....does it go off all by itself...
08-09-2012, 05:06 PM | #18 |
Good luck, hopefully it's air in the line. but with the pedal being hard, I don't think so. I have very low vacuum on the engine, 11 -13 inches. I have replaced about everything and added a vacuum pump. I got the best brakes I've had , but I still can't do an emergency stop. I am installing a hydraulic power assist sytem. That will put out over 1800 psi to the wheels. I should have it done in the next week or two. I'll let you know how it goes.
08-09-2012, 07:10 PM | #19 |
What quality level are the shoes that were installed? Cheap linings will glaze and overheat, causing poor performance. You might want to check for "hard spots" (blue from heat) in the drums. Hard spots will result in a high pedal, but poor braking.
There is not any remedy other than replacing the drums, as the spots are usually too deep to turn out on a lathe.
1971 GMC C2500 Custom Camper - Second Owner. 350/TH350, Dana 60 Rear. |
08-09-2012, 08:22 PM | #20 | |
08-09-2012, 09:51 PM | #21 |
Drums were good, turned and Wagner shoes used.
08-09-2012, 11:02 PM | #22 |
Even a GOOD shoe can overheat & glaze....The "achilles heel" of having drum brakes is they cant dissipate heat very well...Other than that they are actually better than disc brakes as far as friction surface & "cold" stopping power.
08-10-2012, 10:20 PM | #23 |
the red brake light will only come on for two reasons, 1- parking brake pedal has been depressed and 2- loss of hydraulic pressure.
08-16-2012, 09:32 PM | #24 |
Latest report: bled brakes, rear first, pedal hardly went down when opening rear bleeders, pedal did go down when I bled front.
Driver side cylinder was tough to open, then leaked after bleeding. Going to take drum off tomorrow and probably replace the wheel cylinder to stop leaking. Still wondering why the pedal didn't hardly go down when I opened the rear bleeders??? Thanks Posted via Mobile Device |
08-16-2012, 10:13 PM | #25 |
The piston in the combination valve ("proportioning valve") may be off-center and stuck, blocking fluid flow to the rear brakes. Normally, if the piston is offset, bleeding the opposite end (in this case, the front) will cause it to return to a centered position. There may be a lot of crud in the valve causing it to stick.
Thread Tools | |
Display Modes | |
