08-10-2012, 11:12 PM | #1 |
brake problem
So here's the story:
I have a'49 3100 that I am trying to convert to power brakes. I installed a braket kit from CPP with the recomended Mustang master cylinder & booster. I also installed the 1/2 " extension to the pedal linkage. I am using the stock pedal with the under cab mounting along with the stock 11" drums front & rear. I did install a 10 # check valve in the m/c since the m/c is for a disc / drum combo. Now the problem. The pedal goes down about 4" before the brakes engage. Ive got the brakes adjusted to a slight drag, the system has been vaccume bled etc. I'm at a loss to solve this problem. Any ideas ???? Thanks. |
08-11-2012, 12:43 AM | #2 |
Re: brake problem
dose it do it with the engine off? if so I could be the pushrod in the booster is too short.
08-11-2012, 08:12 AM | #3 |
Re: brake problem
My first thought is that you need a m/c for drum brakes. There is very little fluid movement in a disc brake system since there is so little movement of the brake piston. Using a disc m/c with drums where there is more fluid movement might be causing your low pedal.
08-11-2012, 01:30 PM | #4 |
Re: brake problem
Russ is right, you need a drum/drum MC, fluid dynamics between disc and drum brakes are much different.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
08-12-2012, 11:18 AM | #5 |
Re: brake problem
I had to adjust the pushrod between the master cylinder and the booster all the way out to get mine to work.
Thread Tools | |
Display Modes | |
