Old 08-12-2012, 10:41 AM   #1
ChopperCity256
ChopperCity256's Avatar
Can you lay frame on 22'' 9.5w 5.7bs?
will those wheel be able to tuck in if the truck lays frame. i really want these rims just wont to make sure they will work.. Thanks for any info!
ChopperCity256 is offline   Reply With Quote
Old 08-12-2012, 10:52 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Can you lay frame on 22'' 9.5w 5.7bs?
What year truck?
What suspension?
What rearend?
Need just a little more info.
Keith
Convert to disc brakes.
Old 08-12-2012, 10:56 AM   #3
ChopperCity256
1967 c10 swb on a 1970 frame with an 86 front crossmember with drop cups in the lower control arms. I have the Porterbuilt extreme rear drop member 4 link setup.
Old 08-12-2012, 10:56 AM   #4
ChopperCity256
oh the front has a 2.5'' Z in it..
Old 08-12-2012, 10:57 AM   #5
ChopperCity256
stock 86 spindles. i can get 2.5'' or 3'' if i need to.
Old 08-12-2012, 11:07 AM   #6
lolife99
lolife99's Avatar
Most 8.5 wheels require a 5.25" backspace just to get them inside the fenders.
Nate Porter recommends this size for his Dropmember equipped trucks that are narrowed 1.5" MORE per side because of the Dropmembers narrower track width.
You are trying to stuff a 9.5 wheel with a 5.7 bs on a stock width crossmember.
If you do the math,... Your wheels are the same as a 8.5 with a 4.7" bs.
They will stick out 1/2" more per side, and you still have to deal with the stock crossmember width.
The plus for you, is your stock crossmember will make the tires camber way in at the top.
This might help,... But I still think they are too wide.
If you had a Dropmember and a set of PB narrowed a-arms,... they might work.
Keith
Old 08-12-2012, 11:09 AM   #7
lolife99
lolife99's Avatar
I'm sure you will need the drop spindles also.
Keith
Old 08-12-2012, 11:27 AM   #8
875.3CHEVY
use this http://www.rimsntires.com/specs.jsp measure your current rims and tires and the clearence.and see how much more you can fit.
875.3CHEVY is offline   Reply With Quote
Old 08-12-2012, 11:36 AM   #9
lolife99
lolife99's Avatar
You would have to convert wheel backspace to wheel offset to use that calculator.
That would be a +12 offset for those 9.5" wide wheels.
Keith
Old 08-12-2012, 11:37 AM   #10
ChopperCity256
it has 14mm offset
Old 08-12-2012, 11:45 AM   #11
lolife99
lolife99's Avatar
Must be slightly more than 5.7" bs.
Keith
Old 08-12-2012, 11:46 AM   #12
ChopperCity256
5.73
Old 08-12-2012, 12:03 PM   #13
ChopperCity256
looks to me on that website that they will work depending on tire height and weather or not i have fender wells or not..
Old 08-12-2012, 12:11 PM   #14
lolife99
lolife99's Avatar
Let us know what you find out.
Keith
Old 08-12-2012, 12:28 PM   #15
ChopperCity256
will do
Old 08-16-2012, 10:06 PM   #16
The Big Green
A 40 offset will lay body on your setup with a 29in tire on that wheel. You can also turn at a stop light at an inch off the pavement. That will put you like 6.7bs.
The Big Green is offline   Reply With Quote
Thread Tools
Display Modes
