Old 05-23-2003, 01:58 AM   #1
440 charger
Lightbulb best way to run a gas tank?
i wanna take the tank out of the cab but i am kinda worried about using a fuel cell(the one im thinking of using is a 16 gal),the ones ive seen ran on these trucks hang down about half way over the rear end and i wanna run bags!!do you think this will be a prob.?will it sit on the tank when i lower it?would a blazer tank be a better bet?how low would a blazer tank hang down?what should i do?
440 charger is offline   Reply With Quote
Old 05-23-2003, 06:02 AM   #2
Riveted1
Tasty Cakes!
Riveted1's Avatar
Hey 440,
Try doing a search on fuel cells. This subject has been covered many times. I think a blazer tank hangs lower than most fuel cells. There are several guys here that are running bags and fuel cells w/out problems. I'm thinking XXL and JaySpot were using them? Anyway, like I said, try a search.....
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 05-23-2003, 07:09 AM   #3
Seke69
Space Cadet
Seke69's Avatar
I think a lot of the custom tanks, seem to hang lower than the blazer tanks, like Riveted1 said, try a search for tanks. I haven't done this yet myself, but I plan on using a blazer tank, which looks like it'd sit (stock height) just above (2-3"?) over the top line of the diff. Hopefully I can get around to it this weekend, I'll try to post pics if I do.
Seke69 is offline   Reply With Quote
Old 05-23-2003, 09:02 AM   #4
MOTHERTRUCKERS
Blazer tanks we sell are 13"tall x 17" long x 26" wide
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 05-23-2003, 01:18 PM   #5
cruzn72
I used a summit aluminum cell and mounted it behind the rear end where the spare used to set. It is a 20 gallon tank.
http://photos.yahoo.com/cruzn72@pacbell.net
cruzn72 is offline   Reply With Quote
Old 05-23-2003, 06:06 PM   #6
Tracy Focht
Tracy Focht's Avatar
I have one, 16 gallon, gonna do the same thing...I like it.
Tracy Focht is offline   Reply With Quote
Old 05-23-2003, 06:23 PM   #7
68 Suburban
68 Suburban's Avatar
16 gallon tank @ 5 miles a gallon. You better be plotting your way to the gas stations :p j/k
By the way your trucks progress is looking great.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-23-2003, 06:53 PM   #8
chevykid1969
chevykid1969's Avatar
16 gallon tank
Just finished putting in a 16 gallon tank in . i dont think that clearence will be a problem . it is only about 9 inches deep so it hangs above the whole rear end.
chevykid1969 is offline   Reply With Quote
Old 05-23-2003, 06:55 PM   #9
chevykid1969
another
Another view
Old 05-23-2003, 06:56 PM   #10
jayssunm
jayssunm's Avatar
Crusin,
How does the gas tank fit?? Which gas tank did you get. I looked online, and they have lots to choose from.
Jay
67 Fleetside Shortie, small window, slip & slide tranny
Upgrades--small block, tilt column, disc 5 lug conversion (front and rear),
Future Projects--suburban gas tank under the bed, rear roll pan, better gas mileage (currently about 6-10 MPG)
jayssunm is offline   Reply With Quote
Old 05-23-2003, 07:11 PM   #11
440 charger
thank you for the pic... ive been wanting to see how far it hangs down!!!!i would aslo like to know which one you ordered!!
Old 05-23-2003, 08:29 PM   #12
chevykid1969
I have a 16 gallon street fuel cell that i ordered from Summit Racing. it fit in real nice. if need any more help/pics just let me know.
Old 05-23-2003, 09:51 PM   #13
Stroker
cruzn, I would also be interested in more info on the 20 gal tank. I was going to use the 16 gal because I knew a lot of members had used it with out problem but a few more gal wouldn't be a bad idea if it doens't hang to low. Have most of you used poly tanks with the foam baffles any trouble with them? Thanks..Stroker
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 05-23-2003, 11:43 PM   #14
72MARIO
72MARIO's Avatar
I am sending my Blazer tank back. and then I am buying a 20 gallon aluminum fule cell they cost $420 CDN. with baffles and no foam. I am going to fab up my own fule neck so that I can run a filler neck using 1 1/2 " filler tube. Size is 24 x 18 x 10 shouls not hang too far down.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 05-24-2003, 09:08 AM   #15
RACING29
I mounted a summit 20 gallon aluminum fuel cell in the bed. works great?
1967 Chevy truck, R1 racing seats, 4 point racing harness, 4/6 drop, primered blue, soon to be shaved, 350- 060. over, flat top pistons, Eagle rods, Edelbrock Aluminum heads, 1.5 Scorpion roller rockers, Lunati 515" cam, mallory ignition, Holley 750 double pumper carb, Built 350 turbo trans, 2500-2800 boss hog stall, 20 gallon aluminum fuel cell!!!
RACING29 is offline   Reply With Quote
Old 05-24-2003, 12:02 PM   #16
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
If you find that whatever tank you use sets too low you could always take a page from the 4X4 bible and put a skid plate under it.That would take the danger of puncturing your tank out of the equation.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-24-2003, 06:47 PM   #17
Tracy Focht
LOL...yea, your right...and thanks...I can't wait...
Thread Tools
Display Modes
