Old 08-13-2012, 06:12 PM   #1
hula
Lateral driveshaft angle with Dana 60 swap.
Swapping in a Dana 60 from a 1969 3/4 ton C20 2WD into my 1968 K20 4x4 that had an Eaton. Talked to the guy doing it at a differential shop and he said there may be a little lateral drive shaft angle being the differential may not center up. I'm going to look at it tomorrow while they fabricate the spring perches and shock mounts. Is there a maximum lateral angle for the drive shaft? Will rebalancing it be necessary?
hula is offline   Reply With Quote
Old 08-13-2012, 09:41 PM   #2
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: Lateral driveshaft angle with Dana 60 swap.
My 68 K20 came stock with a 60 rear, so I don't think there would be too much of an issue. Unfortunately I don't remember how much (if any) offset there is to give a more exact answer.
Math and assumptions:
2" offset and 48" shaft length = 2.4 degrees of offset. It will increase with larger offset or shorter length and decrease with less offset or a longer driveshaft.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Thread Tools
Display Modes
