Old 08-14-2012, 04:35 PM   #1
eventytoo
Vintage Air 54 chevy
Iv installed a Vintage Air gen 2 compac unit under the dash with the 2 brackets included in the kit. One backet from the dash to the unit the other from the hood hinge bolt to the unit.
Is this correct ? The unit seems to bounce around quite a bit going down the road.
Can anyone tell me how they installed their unit? Or better yet pictures.
eventytoo is offline   Reply With Quote
Old 08-14-2012, 06:16 PM   #2
_Ogre
_Ogre's Avatar
Re: Vintage Air 54 chevy
i used a va gen II compac on my 58
should be 3 brackets to mount it
front screw, top left (upside down Y) and rear right.
it should be very secure with no movement.
i made my own brackets, except for the upside down Y
shop air compressor timer
Old 08-14-2012, 07:59 PM   #3
parkwood
parkwood's Avatar
what i did i don't think you can do it now if your truck is painted.. i welded 1/2" x 1" tube to the fire wall and bolted the a/c to that with a brace to the bottom of the dash for extra support..
For you put another brace to something to stop the a/c from moving around.
parkwood is offline   Reply With Quote
Old 08-14-2012, 10:19 PM   #4
coralhead
coralhead's Avatar
You should have three brackets. There should be a flat strap that have the ends twisted 90 degrees that attaches to the firewall near the center, one to the hood hinge bolt as you said and the one to the inner dash edge.
coralhead is offline   Reply With Quote
Old 08-15-2012, 10:05 AM   #5
eventytoo
Ok so I looked at it again iv got 3 brackets installed. I forgot about the bracket that goes from the firewall to the unit witch i do have installed.
Old 08-15-2012, 10:26 AM   #6
_Ogre
_Ogre's Avatar
even with 3 brackets you need to lock it in so the unit wont move
brace it to the dash or the firewall, tough to do when the truck is painted
lots of holes in the bottom of the dash, see which one you can brace off of
Old 08-15-2012, 10:02 PM   #7
coralhead
coralhead's Avatar
Agree, I added another brace just under the glovebox to stiffen up the mount.
Thread Tools
Display Modes
