Old 05-23-2003, 06:12 PM   #1
dubie
dubie's Avatar
67-72 Trailers??
I know landon4421 has a utility trailer made from a 67-72 long fleetside, but does anyone else have 1? I just bought a 70 rolling chassis that I want to turn into a trailer to haul parts and camping supplies in.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 05-23-2003, 06:18 PM   #2
68 Suburban
68 Suburban's Avatar
Like this one?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2415330203
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-23-2003, 06:19 PM   #3
SEVEND2
SEVEND2's Avatar
hmm Not sure about that , but i have a 72 terry travel trailer 25" i still use and is very clean,
((hope to paint the same as truck))
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 05-23-2003, 06:39 PM   #4
StingRay
StingRay's Avatar
I've done it before. After the cab is off just cut the frame where it is still straight as far forward as you can get. Then cut two slices per side one on the upper frame flange and one on the lower just in front of the box. Take measurements. Bend the frame flanges up/down for and aft of the slices so that they will not interfere with each other and then you can then bend the frame rails by hand inward till they meet at a point. Check your measurements here as well to make sure it is centered. I used some square tubing welded on at that point to fasten a coupler to but one of those A- frame couplers might just bolt right on. Next weld up the tabs where he frame flanges overlap eachother. I cut the factory wiring harnes and hooked up a plug and presto you have a trailer in a couple of hours. Don't worry guys I used the rattiest frame and most trashed box I had. It saved em from the scrap yard and now my buddy has a trailer. I even get to borrow it when I need it.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 05-23-2003, 07:09 PM   #5
Blue_71
Bloo
Blue_71's Avatar
71 bed, i bought it this way but the whole bed floor was gone (literly) only thing holding the sides on is the crossmembers and a few stray peices of metal
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 05-23-2003, 07:10 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
lol i was gonna do the same thing foiund its easier to use the rectangle tubing than to try to use an A frame for making the hitch part
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-23-2003, 08:04 PM   #7
jerry moss
Born Psycho
jerry moss's Avatar
i have a longbox trailer with a very nice ,original paint bed on it. even the floor is near perfect. i know you guys in the rustbelt are calling me all sorts of names right now,lol. but hey, i only paid 50 bucks for the bed and needed somewhere to use it so i made a 3/4 ton leafspring trailer out of it. i used an old eaton rearend, pulled out the third member, sawed of the axle shafts, packed the bearings with grease. i also welded a flat plate over the hole where the third member was and rotated the housing for added ground clearance, welded on new spring pads and shock mounts and been using it for several years.
my dad also has one but the bed on his is beat pretty bad-- his was free, all we had to do was weld on a coupler and tow it home. it's also a 3/4 ton leaf spring.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 05-24-2003, 12:00 AM   #8
Rod
I like the trailer ground clearance tips...LOL.. Maybe I'll try that one day.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-24-2003, 01:25 AM   #9
dinnut
dinnut's Avatar
i wanna make a bed out of one
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 05-24-2003, 02:31 PM   #10
Mike C
Mike C's Avatar
I haven't done it yet, but the plan is in the works! I have two I want to do, one is a longbed fleet with steel floor that I have a camper shell for. The other is a long step that has bolt on tool boxes that replaced the step fenders. Too cool. Most likely, I'll buy trailer springs and make a frame from square tube. The step one I'll use as a work trailer and paint bronze like my truck. The fleet will be a camping/off-road trailer with 35" tires like the Jimmy and using a pintle hitch for max articulation. I'll mount trailer jacks on all 4 corners so it can be leveled and stabilized.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Thread Tools
Display Modes
