Gauge wiring
Ok so i have a problem. I did an lt1 engine swap on my 1971 Chevy c10. and at the time I had the non gauge cluster and now I have a gauge cluster from a 72 gmc. I have changed all the pins around for the blinkers, fuel gauge temp (but I need to find a sending unit that will work for the temp), but I can get the battery to work on the cluster. I have the fuse able link still but its not on the block its strait to the battery, and I don't have the external regulator anymore I am running the lt1 alternator. How do I make it to run the battery gauge?
Thank you |
Re: Gauge wiring
I still haven't had any luck getting the battery gauge to work I played with it and can get it to charge and decharge with the key off and turn the key on and do nothing. I have an adapter that connects 2 brown and a blue to the alternator on my lt1 and an aftermarket gauge shows a charge, but I would like to nix those gauges and use the factory gauge cluster
Re: Gauge wiring
Ok, Found out I shouldn't run that high of an alternator on that gauge. I got an 80's gauge and with a little fab work I am going to put it where the factory gauge was suppose to be. just sticking it behind where its suppose to be and it looks like its suppose to be there
Thread Tools | |
Display Modes | |
