08-27-2012, 03:53 PM | #1 |
gear box
does any know the procedure on how to adjust gearbox to remove to much play in steering?
08-27-2012, 04:04 PM | #2 |
TOTY 2006
Re: gear box
Copied from El camino site, but pretty much the same for our trucks.
It is assumed that the rest of your steering suspension is tight. Also, the nut with the allen head stud on top of the steering gearbox is what you are adjusting. Tools 3/16" allen wrench 5/8" box end wrench lubricating oil Procedure use oil to lubricate threads of locknut and adjustment plug (right on top, can't miss it) raise the front end of the car so both front wheels are off the ground put the box end wrench on the locknut use allen wrench to hold the adjustment plug at the top of the box holding the allen wrench stationary, loosen the locknut with the box end wrench several turns turn the adjustment plug clockwise until snug to remove slack, then back it out 90 degrees. holding the allen wrench stationary, tighten the locknut, remove wrenches start car, run steering wheel through full rotation, checking for binding if binding, repeat steps 3-8, backing out adjustment plug slightly more lower car from jack (stands) drive car, note improvement! |
08-27-2012, 04:12 PM | #3 |
Re: gear box
thanks a lot i thought that was how it was done but wasnt sure.
08-27-2012, 04:16 PM | #4 |
20' Daredevil (Ret)
Re: gear box
I'll just add this: It's a temporary patch at best. If your steering box is that sloppy, it's worn out and should be replaced soon. But I have done it too, so.....
It probably won't take much to be effective. And it's easy to go too far. If your steering wheel doesn't readily return to center after you've turned it (while driving), then you've gone too far. Loosen it just a tad & try it again.
Thread Tools | |
Display Modes | |
