Old 08-28-2012, 07:06 PM   #1
davepl
davepl's Avatar
Flex plates - all the same or is there a benefit?
My existing '70 402 flexplate has a couple of chipped teeth and a note from the machine shop that did the engine machining and balancing that says "Bad - Do Not Use", with no other explanation.
So, I figured I'd just order a new one, but I see they range from $35.99 to over $200, even within the same brand (Pioneer, in this case).
Granted the really expensive ones are SFI certified which I don't need, but beyond that is there really any difference amongst them? On O'Reily's alone I have six to choose from, not sure what to look for.
Thanks!
Dave
PS: If if matters, I'll be running a TH200-4R behind it with a smaller than stock converter, but I don't think it should matter. The original is your standard neutral-balanced, 14 inch, 168 toother.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-28-2012, 07:16 PM   #2
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Re: Flex plates - all the same or is there a benefit?
My old GM flexplate was messed up & had gone egg-shaped. I replaced it with the cheapest sfi approved one Summit had @ $50ish bucks. As long as it's the proper balance (internal), for your type of crankshaft (2 piece seal) & the right tooth count, they are all the same...
http://www.summitracing.com/search/?...l&Ns=Price|Asc
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 08-28-2012, 08:08 PM   #3
oneperfectrun
oneperfectrun's Avatar
Originally Posted by passthebuck View Post
My old flexplate was messed up & had gone egg-shaped. I replaced it with the cheapest sfi approved one Summit had @ $50ish bucks. As long as it's the proper balance (internal), for your type of crankshaft (2 piece seal) & the right tooth count, they are all the same...
^^This. If you are not gonna be spinning engine alot of rpm's it won't make any difference which one you choose.
oneperfectrun is offline   Reply With Quote
Old 08-28-2012, 08:20 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
A lot of the higher priced flexplates have the SFI ratings so they can be used in drag racing and roundy round stuff. If you've just got a stock or warmed over 402... a lower dollar original replacement will be fine.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-28-2012, 10:38 PM   #5
Lee H
Lee H's Avatar
Not all the same, go with a GM flex plate or risk starter problems down the road. Just my humble opinion.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-28-2012, 11:19 PM   #6
davepl
davepl's Avatar
Anyone know which one I'd need? My best guess is 471598:
Part Number
Outside Diameter
Year
Crank Flange Bolt Pattern
Converter Bolt Pattern*
Starter Ring Gear Teeth
Notes
471598
14"
1970-85
3.58"
10.75", 11.50"
168
For internally balanced engine with two-piece crank seal.
Thread Tools
Display Modes
