Old 08-31-2012, 10:10 PM   #1
AusTx68
AusTx68's Avatar
Truck won't start after jetting carb
Carb is a Holley 670 Street Avenger. It's been on the truck a few weeks. Bought it new in the box. Over three weeks time I put maybe 50 miles on it. Checked the plugs and they read lean. Real lean. I drained and removed the primary bowl. Found it had two 63 jets. I added two 69's. Pulled the secondaries and found 72's. I left those in place. Put it all back together and now it won't start. Bowl levels are normal as viewed in the sight glass. Any guesses?
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 08-31-2012, 10:29 PM   #2
Roninwolf
Roninwolf's Avatar
Re: Truck won't start after jetting carb
Is the acc pump arm working right as in the squirter working?
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=531265
72 Cheyenne Super
90 Z71 S.B. 434 C.I. Stroker
78 Camaro Z28 (gave to wife she is restoring it)
Roninwolf is offline   Reply With Quote
Old 08-31-2012, 10:47 PM   #3
AusTx68
AusTx68's Avatar
Yep. Everything appears to be working fine. It's strange. Even if I spray starter fluid into the carb it won't start. It's getting fuel and has spark. Doens't make sense.
Old 08-31-2012, 11:46 PM   #4
Roninwolf
Roninwolf's Avatar
is it flooded pull some plugs see if they are wet. starting fluid i never use on gas engines can do to much harm than good.
My build thread
72 Cheyenne Super
Old 09-01-2012, 12:02 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Sounds flooded to me too...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-01-2012, 01:10 PM   #6
biggestjohn
When did you check for spark?
If it was lean, and you never got it to start, how would the plugs get gas fouled?
It sure sounds to me that your not getting spark.
......its not what your askin', its what your gettin'....
.......every time I screw up, I learn something. Needless to say, I'm learning all the time............
biggestjohn is offline   Reply With Quote
Old 09-01-2012, 11:19 PM   #7
AusTx68
AusTx68's Avatar
I also think it's a spark problem. The spark looks weak. It doesn't have that flash to it. I will put an ohm meter on the coil and see what I find.
Old 09-02-2012, 05:22 PM   #8
AusTx68
AusTx68's Avatar
It appears the coil is bad. That's based on the following ohm readings.
BAT to TACH = .7 (good value)
BAT to Carb Button under cap = No reading at all. I understand this to be a short in the secondary coils. I removed the coil and took the same measurement directly on the coil. Also zero reading.
I'm going to get a new coil and see what happens. I will run the same measurements on the new coil before install.
Old 09-03-2012, 01:33 PM   #9
AusTx68
AusTx68's Avatar
Well, the coil measurements didn't mean a thing. Guess you can't believe everything you read on the Internet. The new coil measured the same. I still put it in. Same results. I'm grasping for straws at this point. Spark looks weak. I have 12.4 volts at the dizzy. Drops to 10 when starting. Ran a 10g wire directly from battery to dizzy. Still not starting. I get a few pops but nothing more. So far I've spend a solid 3 days on the problem. Something that I would normally assume a simple fix has turned into major frustration. At this point I'm going to just walk away and stop messing with it before I put a bullet in it.
Old 09-03-2012, 05:31 PM   #10
biggestjohn
Go back to basics.
Check timing
You said plugs were real lean,aka: insulators were white ashy color, correct?
Points or HEI? Points, check dwell. contacts OK?
If all else fails, put old jets back in to check if this is the cause. (I doubt it)
Old 09-03-2012, 06:23 PM   #11
Xeen
Xeen's Avatar
AusTx68;
Sorry to hear you are having Igntion system problems.
You might have better luck if you start a new thread over in the main "General Truck Forums-Engine and Drivetrain" section of the boards you will get more dedicated and possibly even expert help over there.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-03-2012, 10:41 PM   #12
AusTx68
AusTx68's Avatar
Go back to basics.
Check timing
Right. Insulators were white ashy color. It's HEI.
At this point I'm thinking to pull the HEI out of my 87 and see what happens. If that doesn't work I'll pull the carb too. Typically I would never cannibalize another truck for the sake of testing but this has be scratching my head.
Originally Posted by Xeen View Post
AusTx68;
I actually started there. After 3 days, 28 views, and 1 response (me), I moved it here and got a better response.
Old 09-03-2012, 11:02 PM   #13
Gonepostal
Gonepostal's Avatar
posible hei module gone bad ?
Gonepostal is offline   Reply With Quote
Old 09-04-2012, 09:09 PM   #14
AusTx68
AusTx68's Avatar
I'm happy to report the truck is now running with all the same parts. I think the problem was in the plug that connects the cap to the dizzy. The plug has 3 wires with female spade connectors. It appears the spade pushed back into the plug and wasn't making a good connection. At least that's my guess. It started after I made sure they were solidly connected. I'm glad it's running but I have a lot of time to make up.
Old 09-05-2012, 05:41 PM   #15
biggestjohn
Your luck sounds as bad as mine.
Thread Tools
Display Modes
