Old 05-26-2003, 01:12 AM   #1
RCWEEKS64
Question Bbc Motor Mounts & 400 Tb Bracket 69 C-10
HEY GUYS SORRY ABOUT MY 1st.POST ON THE BOARD.I DIDN'T RELIZE I WAS IN THE PARTS DEPT..MY QUEST.IS
I HAVE 69 C-10 2wd w/ SBC 307 & 3 ON THE TREE.I'M
REPLACING IT WITH A BBC 454 & 400TB.I'M LOOKING FOR HELP IN THE MOTOR MOUNT & TRANS.BRACKET.I'M ALSO,THINKING OF HEADERS BUT NOT SURE OF CLERANCE ON FRAME AND INNER FINDER? THANKS FOR ANY
INFO.THAT YOU MY HAVE.
RCWEEKS64 is offline   Reply With Quote
Old 05-26-2003, 08:46 AM   #2
I can't help you with specifics as you already have more engine than I do, but welcome to the board.
Old 05-26-2003, 09:23 AM   #3
jmanz69
Careful, they attack...
jmanz69's Avatar
You will want to get a set of BB frame brackets. 71-72 are the most sought after. They lower the engine in the frame, but are more expensive. They also use a different style mount to the engine. 67-70 style are easier to find, cheaper and still work just as well. They use a mount similare to the one you have on your SB, and the engine sits a little higher. If you have the money go for the 72 type, but it's not necessary.
As for the trans bracket, get an auto crossmember out of about any truck. Then you just line it up with the pre-drilled hole n the frame. Which holes you use will depend on which mounts you get.
Hope this helps
jmanz69 is offline   Reply With Quote
Old 05-26-2003, 09:41 AM   #4
Desert Rat
Desert Rat's Avatar
things you will need
BB motor towers,BB PS Pump and brackets,Alt Brackets,Pulleys,AT Crossmember,AT column,BB fanshroud,AC brackets if equipped.if you have any questions about this swap email me.I also have most of the parts to changeover.
Desert Rat is offline   Reply With Quote
Old 05-26-2003, 10:38 AM   #5
Orence1
Orence1's Avatar
RC,
Micah (Desert Rat) is THE MAN when it comes to the parts necessary to make your swap. He provided all the stuff that I needed for my BB conversion. Give him a shot. You won't be disappointed.
Larry
Orence1 is offline   Reply With Quote
Old 05-27-2003, 11:45 AM   #6
1971Stepside
Almost Satisfied
1971Stepside's Avatar
BB stands
Actually the 67 - 71 stands are the same. You can pick them up pretty cheap, but the engine mounts are pretty pricey. Or you can find a set of 72 stands. The stands are more expensive, but the mounts are cheap. The 72 stands let the motor sit a little better in the frame IMO. Here is a pic of the 72 stands....
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 05-27-2003, 11:55 AM   #7
BIG ORANGE
BIG ORANGE's Avatar
RCWEEKS sent you a PM with price for everything you need!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 05-27-2003, 12:59 PM   #8
RCWEEKS64
THANKS FOR EVERYONES HELP !!! HEY, BIG ORANGE I DON'T WANT TO SOUND LIKE AN RETARD? BUT, WHAT'S A PM IN BOARD LINGO? THANKS AGAIN FOR THE INFO.
Old 05-27-2003, 10:30 PM   #9
BIG ORANGE
BIG ORANGE's Avatar
Click on the usercp at the top of the page and you will see!
Old 05-29-2003, 05:25 AM   #10
71PROSTBLAZER
big orange , if you would send me the list along with the prices as well ....thanks
71PROSTBLAZER is offline   Reply With Quote
Thread Tools
Display Modes
