Old 09-06-2012, 08:21 PM   #1
sigshooter
sigshooter's Avatar
Automatic brake pedal, is there a difference?
I recently ordered a complete power brake set up from a member and it came complete with the bracket under the dash and what was described as a rare automatic only brake pedal assy. I am not saying it was falsely advertised, I just cant see a difference between my 4 speed brake pedal and the automatic one. I of course removed the clutch pedal years ago when I changed over to an Auto trans but my brake pedal is the 4 speed one still.
What am I missing? I want to know before I go to the trouble to change it and there is no difference, or worse throw it away and there is a difference I am just not seeing.
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 09-06-2012, 09:02 PM   #2
yelmer
Re: Automatic brake pedal, is there a difference?
they are the same . all the ones that i have ran into
yelmer is offline   Reply With Quote
Old 09-07-2012, 12:19 AM   #3
Captainfab
60-66 Nut
My '66 Suburban is an original auto trans truck, and the brake pedal is the same as what is used in a manual trans truck. At least I have not seen any difference.
Old 09-07-2012, 08:49 AM   #4
sigshooter
sigshooter's Avatar
Thanks guys..... I couldn't tell a diffrernce, but didn't want to over look something. I will put it in a pile of extra parts then
1966 Short stepside
1964 long bed
Old 09-07-2012, 03:49 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
The rarity of the auto brake pedal is found in the pedal pad. It is unique, and to my knowledge has never been reproduced. I have only seen two on Ebay, and they both sold for well over $100. Without the pad, the pedal is nothing special. Here’s what an NOS pad looks like:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 09-07-2012, 04:03 PM   #6
sigshooter
sigshooter's Avatar
So the rarity is in the power brake pad , nothing to do with the automatic
1966 Short stepside
1964 long bed
Old 09-07-2012, 08:14 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
My apologies - my previous post was incorrect. The rare pedal pad isn't unique to automatic transmissions, it is unique to factory power brakes. To the best of my knowledge the auto trans equipped trucks received the same standard pedal pad unless equipped with power brakes.
Claiming the pedal assembly as rare is technically correct, the same as stating a 60-66 automatic steering column is rare. Compared to standard transmission trucks very few auto equipped trucks were produced during this period. But in practical terms the only unique part is the pivot pin. Not too many hot rodders would care about the pin, but to a purist it might have some value by not showing the remains of where the clutch pedal was sawed off.
Old 09-07-2012, 08:52 PM   #8
LT1 Burb
LT1 Burb's Avatar
I need that pad!!!!!!!
LT1 Burb is offline   Reply With Quote
Old 09-09-2012, 02:07 PM   #9
RoyL
RoyL's Avatar
see earlier post:
http://67-72chevytrucks.com/vboard/s...57&postcount=9
I wanted a wider pedal for my 65, so got a pedal from a early 80 "square box" Chevy truck and cut off the small pedal and welded on the wider one.
1965 Suburban
Waiting on Time and Money
RoyL is offline   Reply With Quote
Old 09-11-2012, 05:08 PM   #10
Joemomma1
Joemomma1's Avatar
I have both and will have to look to verify but wouldn't the hole for the push rod be in a lower spot on the pedal arm for the power brakes? I also think there was no stop for the clutch pedal. I'll look tonight.
Joemomma1 is offline   Reply With Quote
Old 09-11-2012, 05:16 PM   #11
kieth
kieth's Avatar
Everything is the same because the activation of the power brake booster is done in the same way as activating the brake booster.
kieth is offline   Reply With Quote
Old 11-03-2013, 07:32 PM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by RoyL View Post
see earlier post:
That's what I'm thinking of doing.
66 C20 Service Truck:
Thread Tools
Display Modes
