Old 09-11-2012, 10:25 AM   #1
rockdogg2020
Mpg Poll
How many mpg are you getting with your setup? Tell the engine size, rear gear, trans, and carburetor.
rockdogg2020 is offline   Reply With Quote
Old 09-11-2012, 10:38 AM   #2
rockdogg2020
Re: Mpg Poll
Was getting 8 mpg with a 230L6, 3 speed, 3.90 gear, 1bbl carb. Now getting 15 - 20 with rebuilt carb, split headers, power steering, petronics kit, new vacuum advance, new thermostat, and 3.38 rear made the biggest difference.
Old 09-11-2012, 10:49 AM   #3
newbe351
Re: Mpg Poll
11.5 city, not sure about highway as I never venture more than 20 -30 miles out but probably 14+ as best as I can estimate. 355 built roller cam sbc, 680 cfm QFT double pumper, RPM Performance intake, headers, etc. with Tremec 5 speed and 3:54 positaction. Was getting 9 at most with original 351 V6 and 4 speed tranny.
newbe351 is offline   Reply With Quote
Old 09-11-2012, 11:16 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Mpg Poll
14.5 city/ 20.4 hwy, 4.8/4l60e/ 12bolt 3.73
with my old 350/400, I was lucky to get 8mpg
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-11-2012, 11:20 AM   #5
luvbowties
luvbowties's Avatar
Re: Mpg Poll
12 with all city--dunno re: hiway, but would think much better. Setup is stock '97 5.7 Vortec w/700R4, 3.73 rear, 27-inch tires, headers, GM-hei dist, and 'perfect' quadrajet. Was doing 11.6 city with 3.73, 3-speed manual, stock '68 307 w/good q'jet, stock points-dist, ex-manifolds w/duals, & 26" tires.
Think would do much better with smaller numerical rear gear. Even after tuning my governor, its slowest 1-2 change is ~16 mph, 2-3 change ~36 mph, and 3-4 change at 46 mph; thus I seldom get into 1:1(3rd gear) if I abide by our mostly 35 mph-zones--meaning I'm running in 2nd gear most of the time!
luvbowties is offline   Reply With Quote
Old 09-11-2012, 12:18 PM   #6
vin63
It's Better With Nitro
vin63's Avatar
Re: Mpg Poll
13-15 mpg in town, and right around 21 mpg on the freeway unloaded. My brake specific on the dyno is .377s at 3500 RPM to .394 at 4600 RPM, so the Kauffman cylinder heads have very efficient combustion chambers. My combo did not like anything above 28 degrees timing.
462 ci Pontiac with a 750 cm vac secondary Holley, 4L80E, 3.70 gears, but with 31" tall tires. After this rebuild, I'm going with a 4150 DP Holley to support a nitrous system and locked out advance, so I expect my mileage will fall off quite a bit.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 09-11-2012, 12:59 PM   #7
boucher racing
boucher racing's Avatar
Re: Mpg Poll
Did about a 50 mile cruise, two lane highway mixed with stop and go.
MPG's = 17 all hand calculated with gps to measure distance.
Engine: inline 250, 8.5:1 compression, Blow-Thru Holley 350cfm 2bbl carb, T3 Turbocharger, 7 psi, HEI ignition, Stock intake/exhaust manifolds
Trans: 87 S10 T5 5 speed
Ratio: 29" tires, 3:73 rear
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 09-11-2012, 01:31 PM   #8
Rich 5150 69
Rich 5150 69's Avatar
Re: Mpg Poll
350/350/373... quadrajet...17 MPG at 60...highway
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 09-11-2012, 03:37 PM   #9
66clow
66clow's Avatar
Re: Mpg Poll
I didn't know anyone's speedo actually worked? As soon as I can get mine working I'll let you know.
66clow is offline   Reply With Quote
Old 09-11-2012, 04:01 PM   #10
rockdogg2020
Re: Mpg Poll
Lol. Mine didn't work when I got it, replaced the cable. Just figured out why my gas gauge doesn't work. New part will be in tomorrow.
Old 09-11-2012, 04:04 PM   #11
newbe351
Re: Mpg Poll
Mine is off by 18%. I check speed with a chart (RPM vs. MPH) on my dash and my tach. I check milage every fill-up and multiply miles by 1.18 then divide by gallons....
Old 09-11-2012, 04:04 PM   #12
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Mpg Poll
Average 13mpg with a 305 V8, Edelbrock 500cfm, TH350, 3.08 and tires are 215/70/15.
Im sure its lower on the highway.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-12-2012, 10:24 AM   #13
T Herder
Re: Mpg Poll
65 GMC K1500, 305E V6, Mallory Maglite distributor, 1988 GM Throttle Body Injection, SM420 with a married Gear Vendors OD, divorced NP 205 transfer case, 4.56 final drive gears, BFG All Terrain 35's, plus a few other things.
I regularly tow a custom Sundowner 4 horse trailer with a GCVW of 18,000 lb. Log book verification shows the best mileage empty has been 18.61 MPG, worst, 7.2 MPG has been with a max load and pulling 21% grades in 4WD.
Average towing mileage runs 12.5-14 MPG, non-towing with a light load has been 14.8-16.4.
Best regards,
T Herder
T Herder is offline   Reply With Quote
Old 09-12-2012, 11:04 AM   #14
cru_zn_29
cru_zn_29's Avatar
Re: Mpg Poll
I am running 5.7 TB 4L60E 3.73 posi 275/60/ 15 in my 66 SB 15 city 20+ on hwy trips. I installed this setup in 1995 and is my daily driver and have over 400 thousand miles and MPG stays consistent.
cru_zn_29 is offline   Reply With Quote
Old 09-12-2012, 11:32 AM   #15
theastronaut
theastronaut's Avatar
Re: Mpg Poll
36.25 MPG in my '64... VW Bug. My truck is actually cheaper on gas; hasn't cost me a cent but pushing it sure is getting old!
theastronaut is offline   Reply With Quote
Old 09-12-2012, 01:56 PM   #16
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Mpg Poll
LMAO
Sick5 is offline   Reply With Quote
Old 09-12-2012, 07:42 PM   #17
corvettejim1968
corvettejim1968's Avatar
Re: Mpg Poll
12.2 mpg
230 six cylinder
3:73 rear end
350 tranny
1 barrel carb
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 09-12-2012, 09:47 PM   #18
jonathan-m
Re: Mpg Poll
I drove mine cross country pretty much loaded to the gills and hauling a trailer full of stuff, and I managed roughly 12 MPG the whole way.
350 sbc
Rockin' a '66 and loving every minute of it
jonathan-m is offline   Reply With Quote
Old 09-12-2012, 11:19 PM   #19
tenni126
Re: Mpg Poll
Aside from my bikes, my truck is my economy car. I get about 14 around town, and right at 21 mpg on the freeway at about 68-70. That's off the GPS since the speedo is busted and I'm too lazy to fix it. I'm running a mild 350 with a 600 edelbrock carb and a 700r4 on 3.73 gears. I try to keep the RPM right at 2100-2200 on the freeway and it does well there. My modern-ish, fuel injected '96 Land Cruiser on the other hand does about 10-11 city and maybe 14-15 freeway on a good day. So I'm happy with the C10
tenni126 is offline   Reply With Quote
Old 09-13-2012, 12:50 AM   #20
cameyer
Re: Mpg Poll
I'm getting 17 with a mix of highway and stop and go in town, with a 327 with quadrajet carb sm420 trans and 12 bolt rear with 4.10 gears and 36 in tires
cameyer is offline   Reply With Quote
Old 09-13-2012, 01:25 AM   #21
weaintscared
weaintscared's Avatar
Re: Mpg Poll
I'm. Hoping to get 15-16 with mine. Say yea right. Check out my build.
weaintscared is offline   Reply With Quote
Thread Tools
Display Modes
