Old 09-12-2012, 11:40 PM   #1
cb1965
cb1965's Avatar
Drive shaft ?
Will a 3/4 ton drive shaft fit a 12 bolt 1/2 ton rear end?
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 09-13-2012, 08:52 AM   #2
chevyrestoguy
chevyrestoguy's Avatar
Re: Drive shaft ?
What year did the 12-bolt rear come out of? One thing to keep in mind: the early driveshafts were smaller in diameter but had bigger u-joints (1350). The later driveshafts had a larger diameter but used a smaller u-joint (1330).
You need to measure the yoke on the 12-bolt and see what it measures out at. This will determine if you have a 1330 or 1350 yoke installed. Use this guide for your measurements:
http://www.actionmachineinc.com/ujoi...ringguide.aspx
Any auto parts store can get you the u-joints. You may have a condition where the driveshaft might be a 1350 size, but the rear end yoke is a 1330 size. Not to worry.....the manufacturers make what's called a "combination" u-joint for just that application. It's very common, and it's probably just the ticket to get your driveshaft to work with the 12-bolt.
As far as the length, you should be OK. The second (or aft) driveshaft rides on a slip spline which will give you a little flexibility to compensate for slight length changes. Between the original Eaton 3/4 ton rear end and a 12-bolt rear end, the length difference is nearly the same.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 09-13-2012, 09:36 AM   #3
cb1965
cb1965's Avatar
Re: Drive shaft ?
My '65 is a 3/4 ton and the rear end is also from a '65. Ill try the measurement method. Thanks for the link.
'66 chevy lwb c10
'65 chevy lwb c20
Old 09-13-2012, 10:56 AM   #4
chevyrestoguy
Re: Drive shaft ?
I think you're going to be OK. I'm pretty certain that you'll have 1350 u-joints on both the driveshaft and the rear end yoke. The later 12-bolts, such as the ones installed in the '73 and up trucks, have 1330 rear end yokes in the half-ton models. I just went through this a few months ago. My original driveshaft had a 1350, and the '79 12-bolt rear had a 1330. I had to buy a combination 1350/1330 u-joint.
My build threads:
Old 11-03-2013, 06:50 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Drive shaft ?
My shortbed 65 has the 2 piece drive shaft.
I'll be swapping from the sm420 to a th350.
Does anyone see an issue with shortening the front shaft to accommodate the th350? If so, I also have a one piece shaft from a 79 suburban, but then I'd probably need to get one of these combination u-joints.
66 C20 Service Truck:
Old 11-03-2013, 06:58 PM   #6
jayoldschool
Moderator
Re: Drive shaft ?
The other thing to consider is the center bearing. The 1/2 likely uses the small top hanger, with the heavier truck having the bottom mount heavy duty bearing.
jayoldschool is offline   Reply With Quote
Old 11-04-2013, 02:14 AM   #7
Captainfab
60-66 Nut
Re: Drive shaft ?
Most of the shortbeds I have seen have a one piece driveshaft. You could have the front shaft shortened, but I would think it would be pretty short.
Old 11-04-2013, 02:20 AM   #8
LostMy65
LostMy65's Avatar
Re: Drive shaft ?
Yep, that's why I always figured on using the one piece I got from my 79 donor.
But then I started reading threads that the u-joints would be different on the 79.
I might just try and find a one piece shaft off a 72 or older truck.
Old 11-04-2013, 03:28 PM   #9
jtrichard
Re: Drive shaft ?
they do make a transition joint that is very common that would most likely work with you rear and the later shaft check with Napa or?? they should have it
jtrichard is offline   Reply With Quote
Old 11-04-2013, 03:35 PM   #10
padresag
Re: Drive shaft ?
they are actually called a "conversion joint"
ron
padresag is offline   Reply With Quote
Thread Tools
Display Modes
