Old 09-15-2012, 01:15 AM   #1
SnS C10
SnS C10's Avatar
what is this from?
hey guys im thinking about putting this intake on my 350 when i rebuild it. its a gm part. aluminum dual plane. any idea as what it is from and if it will increase performace over my stock cast iron manifold?
SnS C10 is offline   Reply With Quote
Old 09-15-2012, 01:22 AM   #2
HotRod C/10
HotRod C/10's Avatar
Re: what is this from?
is there a part # on it?
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 09-15-2012, 01:22 AM   #3
geezer#99
geezer#99's Avatar
It's just an aluminum version of the cast iron one. No difference performance wise.
IIRC they came on some 305's.
geezer#99 is online now   Reply With Quote
Old 09-19-2012, 11:36 AM   #4
SnS C10
SnS C10's Avatar
I have a mid seventies 350 with 882 heads and the stock cast iron intake and q jet carb. Will this manifold bolt up with no modifications in place of the cast iron?
Old 09-19-2012, 11:44 AM   #5
Tinkermc
the only difference I know it is a bit lighter
Tinkermc is offline   Reply With Quote
Old 09-19-2012, 12:27 PM   #6
SnS C10
SnS C10's Avatar
Ok my cast iron manifold is pretty best up and guy I bought the truck from gave me this one so im hoping it fits without a problem.
Old 09-19-2012, 12:55 PM   #7
rollinhard
rollinhard's Avatar
It's lighter and will disapate heat better. I'd put it on if I had it.
If you can't impress them with your inteligence, dazzle'm with your stupidity
1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe
rollinhard is offline   Reply With Quote
Old 09-20-2012, 12:13 AM   #8
WIDESIDE72
WIDESIDE72's Avatar
x2
WIDESIDE72 is offline   Reply With Quote
Old 09-20-2012, 12:35 AM   #9
SnS C10
SnS C10's Avatar
Ok thanks guys I will be swapping the manifold in about a week once I get the heads and block cleaned up. They both have a lot of blocked openings on the water passages which basically blew my head gaskets and put water in the oil.
Old 09-20-2012, 11:18 PM   #10
poppy510
I replaced the cast iron version on my 454 with a performer. Went from sluggish to a neck snapping tire roaster. Runs SO much better in general.
I suggest getting rid of it...particularly if you are running a square bore, like a Holley. That one is designed for a spread bore (Q-jet).
The only disadvantage with the modern manny is it doesn't look original.
poppy510 is offline   Reply With Quote
Thread Tools
Display Modes
