Old 09-17-2012, 12:55 PM   #1
GGinferno
DiablosWeldingFabrication
GGinferno's Avatar
Early Classic Spindles / lower control arms
I have a problem let see if you guys can help, I have early classic drop spindles I called the tech support to ask if ican swap the bottom arms with a newer model so he told me they are from 63-70 and if I want I can keep the 66 upper arms and I can switch the bottom from any 63-70 pick???? The reason I'm changing them is because my are all f$ck up, is this correct?
GGinferno is offline   Reply With Quote
Old 09-17-2012, 01:04 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Early Classic Spindles / lower control arms
yes.
Any 1/2 ton 63-70 arm will work.
71-72 will also work if you use the correct balljoint.
3/4-ton lower a-arms are different.
Keith
Convert to disc brakes.
Old 09-17-2012, 03:53 PM   #3
GGinferno
GGinferno's Avatar
Nice! Kool thanks! Of to the junk yard I go! saved me some money!
Old 09-17-2012, 09:19 PM   #4
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
glad you finally got your answer BUT you need to start a thread and show off that truck you been working on and not mention your ladys bug
Sick5 is offline   Reply With Quote
Old 09-17-2012, 09:42 PM   #5
GGinferno
GGinferno's Avatar
Haha! I know! I was planing of doing since the rig is getting torn down as I speak
Thread Tools
Display Modes
