Old 09-18-2012, 08:06 PM   #1
cameyer
FrameVin number help
I need help with my vin number of my 1964 Chevy k10 the vin number on the cab checks out as what it should be but there is also a number on the frame just under the back of the cab on the drivers side this number is 3820303 12 6 24 78. Is this the original frame or was this truck mounted on a later model frame?
cameyer is offline   Reply With Quote
Old 09-18-2012, 08:20 PM   #2
j.kirn
Re: FrameVin number help
the vin on the cab should match up to the nos on the frame,2 places on the frame 1 by steering box on topp of frame and 1 by rear of cab left frame rail
j.kirn is offline   Reply With Quote
Old 09-18-2012, 08:24 PM   #3
j.kirn
post some pics of the frame and such
Old 09-18-2012, 09:00 PM   #4
padresag
is that nbr on top of the fraame by the rear cab mount or on the side of the frame?. looks like a GM part #
ron
padresag is offline   Reply With Quote
Old 09-19-2012, 12:23 AM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I agree, on the side of the rails are part #'s , check the where is my vin # post in the faq section for some shots of where the top frame rail vin stamping is.
Old 09-19-2012, 12:23 AM   #6
cameyer
that's the number by the rear of the cab
Old 09-19-2012, 12:54 AM   #7
jonzcustomshop
1961 crewcab
ok if that # is on top of the frame rail then it is probably form a 78(?), check your frame if it has a 78 frame the cab mounts will show signs of modification, and the front frame horns should be modified too to fit the 60-66 bumper..
you should not be able to see the rear top 64 vin # on top of the frame rail with the cab on.
Thread Tools
Display Modes
