AC Brackets set up...
I have a 1972 3/4 ton 2wd truck that has the factory AC set up and believe it or not still has proper pressure in the system and appears that once the new motor is installed it will still be functioning. At any rate. I had assumed I was ditching the ac or going to an aftermarket so I did not make good notes on the set up.
Ultimately, I need to see how the brackets all go together. So any diagrams or pics would be great....
Confidence is the feeling we have before we fully comprehend the situation |
Re: AC Brackets set up...
More info as to engine would have been helpful. This should help get you started though.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Thread Tools | |
Display Modes | |
