Old 09-26-2012, 11:02 PM   #1
C10TN
C10TN's Avatar
Fuel Octane... Whats Everybody Running?
Got my 66 stepside a couple months ago and just now got it running and road-worthy. It's an in-line six and my question is... what gas should I be running in this old engine? I def will be using the local non-ethanol station but is the low 87 octane ok or would I be better off running 89 or 91? What's everybody running?
C10TN is offline   Reply With Quote
Old 09-26-2012, 11:48 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Fuel Octane... Whats Everybody Running?
Back when these trucks were new, any of the octane levels currently available would have been considered low octane regular. High octane pump gas needed to feed the factory 10:1 compression ratios would have been 100 or better. The only reason to spend more on a higher octane fuel today would be if it pings under hard acceleration on the cheapest regular grade (which is what I use). And it that happens, I’d try retarding the ignition a tad before wasting money on more expensive fuel.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 09-26-2012, 11:57 PM   #3
KJSR
KJSR's Avatar
I use 85 octane in my 1964/230 with no issues.
1936 Chevrolet 1/2t
1964 Chevrolet C10
1964 Chevrolet C10 (sons)
1965 Chevrolet K10 Suburban
1969 Chevrolet C10
1937 Plymouth P4
KJSR is offline   Reply With Quote
Old 09-27-2012, 12:20 AM   #4
corvettejim1968
corvettejim1968's Avatar
we dont even have 85 octane in Arizona i use 91 and it still pings when i get on it.
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 09-27-2012, 12:32 AM   #5
Torqueforce
87 octane works fine for me, absolutely no difference between 87 and 93, running a 250 c.i. though with probably 8.5:1 compression.
Torqueforce is offline   Reply With Quote
Old 09-27-2012, 12:37 AM   #6
joedoh
joedoh's Avatar
Yep yep yep.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 09-27-2012, 08:20 AM   #7
KJSR
KJSR's Avatar
85 was not available in California either and when I moved to Utah I was surprised to see it. I use the 85 in all my cars (even my 36 with 10:1) with no issues. It's all how you tune and drive.....
1936 Chevrolet 1/2t
1964 Chevrolet C10
1969 Chevrolet C10
1937 Plymouth P4
Old 09-27-2012, 08:32 AM   #8
1963c-10
1963c-10's Avatar
Werent they also designed to run on leaded fuel?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-27-2012, 09:12 AM   #9
corvettejim1968
yes the p.o. on my truck redid the heads in 1980 with hardened valve seats.
Old 09-27-2012, 11:29 AM   #10
rockdogg2020
I use 87.
rockdogg2020 is offline   Reply With Quote
Old 09-27-2012, 11:51 AM   #11
1963c-10
1963c-10's Avatar
I use 87 w/a lead gas additive. Dont have any issues w/knocking or pinging. Truck runs/idles happy.
Old 09-27-2012, 12:49 PM   #12
CRGRS 66
CRGRS 66's Avatar
I am running 94 octane from Shell as it is the only fuel sold in canada (ontario anyway) that has NO ethanol in it. It is an occasional driver so they extra dollars on gas is not that big of a deal.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 09-27-2012, 02:07 PM   #13
bbadfred
bbadfred
bbadfred's Avatar
Isn't it also unleaded? I was told that leaded is not available in Canada?
bbadfred is offline   Reply With Quote
Old 09-27-2012, 04:59 PM   #14
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
11.2 comp with a rather large cam my dynamic is good for our 91 E 10 fuel.. Total 34 degrees timing.. All in by 2750.. 14 base with the MSD black bushing.
GMR-PERFORMANCE is offline   Reply With Quote
Old 09-27-2012, 06:23 PM   #15
jchav62
1962 C-10
jchav62's Avatar
I run 86 on all of mine. No issues. When I have a little extra cash, I'll fill it with super/premium, which around here is 91.
The 327 in the '62 is 10.5:1. No issues at all with either 86 or 91. No matter how I drive it. Base timing 10 degrees @ 7000' elevation.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 09-28-2012, 11:30 AM   #16
CRGRS 66
CRGRS 66's Avatar
yes, unleaded... can you still get leaded fuel in the US? Thought it was outlawed all together...
Craigerrr
Old 09-28-2012, 11:40 AM   #17
1963c-10
1963c-10's Avatar
Yes, the fuel is unleaded. The leaded is not for sale.....we have lead additives available through our parts suppliers though.
Thread Tools
Display Modes
