09-27-2012, 02:09 PM | #1 |
Big window cab
I came across a big window truck along with the frame and front clip what is it worth? No title is the only issue. Which is fine i have a good title on my 65 that i already have. Any input on this.
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692 70 C-30 Tow truck AKA Highlighter 02 Silverado 2500 HD CUCVII Tow Rig/DD 1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800 1980 Buick Regal Dirt Stock car |
09-27-2012, 02:22 PM | #2 |
Re: Big window cab
Well, the answer is really up to you, what is it worth to you? Theres so many variables, rust, dents, damage, etc... Post some pics and I can only tell you what I would pay
09-27-2012, 02:53 PM | #3 |
Re: Big window cab
Check your local laws on the cab w/no title. There is a vin on the cab. If its not able to be used, its only worth parts. If its able to be used and rust free its worth a lil more. Maybe some pics?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
09-27-2012, 03:13 PM | #4 |
Re: Big window cab
Ok Ill keep it simple, I can get a cab big back window that from pics its in great shape, also hood and fenders. the cab has one dent and good doors on it. Also has an unknown condition V-8 looks to be later model. I'd post pics but trying to remember how
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692 70 C-30 Tow truck AKA Highlighter 02 Silverado 2500 HD CUCVII Tow Rig/DD 1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800 1980 Buick Regal Dirt Stock car Last edited by Racer2172; 09-27-2012 at 03:21 PM. |
09-27-2012, 03:14 PM | #5 |
Re: Big window cab
Figured it out
09-27-2012, 03:38 PM | #6 |
Re: Big window cab
Cab and body look solid from here. I would personally have a problem with more than 1,200... That's because I have a truck now with some rust issues that I would love to get a new cab for. Thats just me though!
09-27-2012, 03:43 PM | #7 |
Re: Big window cab
Sheet metal looks to be in good condition. Have you gone underneath the truck to look at cab supports, cab corners and inner rockers? These are some of the typical areas to look for. The brow over the glass and pillers are other areas to check for rust. If its all in decent shape...I'd say a couple hundred bucks. Doors...are they complete? Check bottom for rust areas and extreme left/right corners. The trim on the windshield is a plus also. Do you plan on installing the side trim? If not, factor in time to fill all the holes also.
09-27-2012, 03:53 PM | #8 |
Re: Big window cab
Im looking at strictly parts, its 90 miles away from me, but it looks better than the cab i currently have which has drip issues as well as normal dents and dings these old trucks have from life of labor. It has good fenders too that come with it. Thanks for the input
09-27-2012, 04:28 PM | #9 |
Re: Big window cab
Kind of see the difference in price though? I was at a grand assuming zero rust, someone else at a few hundred, so its all dependent.
09-27-2012, 05:05 PM | #10 |
Re: Big window cab
Can see that so ill take a middle of the road average it is still higher than the asking price so i think i could make out all right. Just waiting for a response from the owner now.
09-27-2012, 05:30 PM | #11 |
Re: Big window cab
The wide glass is not as common as the small window. So if you can do some checking on the vin. It looks to be in good shape. Will they sell the cab with doors only?
Posted via Mobile Device |
09-27-2012, 05:50 PM | #12 |
Re: Big window cab
Its all or nothing on the sale. It has an unknown supposed to run v-8 under the hood too. I'll get the whole thing if I can then what i dont use it will be recylced on here.
09-27-2012, 07:56 PM | #13 |
Re: Big window cab
If it was just the big window cab and doors average would be 500 dollars here in Arizona.
http://s994.photobucket.com/albums/af62/ScottAz2/ |
09-27-2012, 08:27 PM | #14 |
Re: Big window cab
with no title , no more than 500.00 max.
09-27-2012, 10:13 PM | #15 |
Re: Big window cab
I paid 300 with salvage title, wide back window, doors and cab, Oklahoma!
09-28-2012, 12:36 AM | #16 |
60-66 Nut
Re: Big window cab
I wouldn't pay more than $500.00 without a title. If you could find the person who the truck was last titled to, they can file for a lost title and transfer it to you all at once. At least that can be done here in Idaho.
09-28-2012, 01:06 AM | #17 |
Re: Big window cab
Not saying that I have not saying that I haven't but why are so many people afraid to swap vin numbers from one cab to another? I understand the legalities of it but who would ever know?
Project Change of Plans: http://67-72chevytrucks.com/vboard/s...d.php?t=513135 '62 C10 SWB '03 Express Van 5.3l Dead (parting out and using motor) '99 Silverado 4.8l 5 speed 4wd |
09-28-2012, 10:35 AM | #18 |
Re: Big window cab
I know I talked to a few people when a had my gto and they know ppl who bought totaled gto front fire walls to convert the lemans and tempest into gtos. So needless to say when to local wrecking yard here smashed all 4 of the nice gtos it had here SOME ONE snagged all the vin tags from the car becouse the junk yard never turned titles in lol
1966 C-10 long wide- currently with 2 3/4 sectioned crossmember, 3 inch cupped a arms with 2700 bags, 67 master cylinder, in the middle of a v8 swap, soon custom rear wishbone set up and bags 1942 chevy/divco ambulance 1937 chevy truck |
Thread Tools | |
Display Modes | |
