Old 09-29-2012, 06:21 PM   #1
66BlueC10
66 C10 Electrical Help
I have a new CD player in my 66 truck with a new Accel HEI distributor and super coil. The radio has so much feedback that it is not usable. I have replaced all grounds, battery, and alternator. I have read about the radio inteference capacitor. Is this needed? If so, how does it connect?
66BlueC10 is offline   Reply With Quote
Old 09-29-2012, 06:42 PM   #2
Mack B
Mack B's Avatar
Re: 66 C10 Electrical Help
I'm prob not gonna be much help here, but I've heard of this being caused by some hi po plug wires. Have a different set you can try? Is the radio grounded by itself? I know it shouldn't matter, but I've read that can be a culprit also.. Hope that helps
Mack B is offline   Reply With Quote
Old 09-29-2012, 06:46 PM   #3
66BlueC10
The plug wires are new and just standard wires. I have tried several different grounds and all of them give the same results. I have been doing stereo installs for 15+ years and have never run into something like this. I have tried everything.
Old 09-29-2012, 07:49 PM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Got resistor plugs? If not, they will make some noise. I have not seen an alternator cause radio noise.
I have used the noise suppression cap on a radio and it worked fine. It goes inline with the 12volt wire from the radio and there is another ground with it.
Something like this one. Pyramid is junk, but Im using it as an example.
http://compare.ebay.com/like/4003199...Types&var=sbar
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-29-2012, 08:37 PM   #5
66BlueC10
I have actually tried one of those and it did not help. I have also tried different plug wires as well. It is a very strange issue. When the truck is under throttle the radio plays without issue. The second I let off the throttle it pops and cracks to the point of almost cutting off. I can touch the throttle and it stops.
Old 09-30-2012, 09:02 AM   #6
contagious102
contagious102's Avatar
Try a different 12 volt source,maybe straight off the battery.
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline   Reply With Quote
Thread Tools
Display Modes
