Old 09-30-2012, 12:20 PM   #1
peglegs
peglegs's Avatar
74 booster in my 67
i removed everything from a 74, pedal, steering column, booster, m/c, lines & complete suspension. i now have the complete 74 suspension & cradle installed in my 67 my search says the power booster will fit with a new hole & some cutting has anyone done this swap & will the 74 pedal fit? thanks to all
1990 chevy 4x4 with a 1940 IHC body
peglegs is offline   Reply With Quote
Old 10-01-2012, 03:50 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 74 booster in my 67
You don't need the 74 pedal.
Just connect the '74 booster rod to your existing 67 pedal.
When I did this swap back in the 80's,.. I had to lengthen the brake pedal push rod also.
Keith
Convert to disc brakes.
Old 10-01-2012, 06:13 PM   #3
peglegs
peglegs's Avatar
ty lolife99 i thought by using the 74 pedal all wood work in unison u say extend the rod do u mean add something to it or screw it out to make it longer? also by usin the 74 pedal if it fits i would have the larger "brake pedal" as mine is a standard thanks again
Thread Tools
Display Modes
