Old 10-06-2012, 10:35 AM   #1
Slinger60
Slinger60's Avatar
1970 gas pedal swap?
Can you swap a 71 or 72 cable pedal for a mechanical pedal? Is it a striaght bolt up or does it require some work? Thanks Shawn
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=529970
Shawn
Slinger60 is offline   Reply With Quote
Old 10-06-2012, 11:15 AM   #2
67c10rustbuket
67c10rustbuket's Avatar
Re: 1970 gas pedal swap?
Yes you can put a 71-72 pedal in a 67-70. You can fab an adapter or buy one for $35 from LFD : LINK
You will have to drill a hole for the cable, and provide your own 71-72 pedal assembly.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 10-06-2012, 11:17 AM   #3
67c10rustbuket
pic of the adapter.
Dan <---(my name)
Old 10-06-2012, 12:09 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If you imagine that adapter turned 90 degrees to the left (counter-clockwise) you can see the LFD in the face of the part. I had to look at it to see what the slots were for. Nice way to ID your piece. Good thinking.
Member Nr. 2770
Old 10-06-2012, 04:03 PM   #5
SS Tim
SS Tim's Avatar
Is this "as delivered" with burred threaded holes like that? As far as hacking their name through it, that is a expensive production step for $35 part that should be about $20.
SS Tim is offline   Reply With Quote
Old 10-06-2012, 11:51 PM   #6
Slinger60
Slinger60's Avatar
Thanks for the info I will get the adapter plate and convert to cable.
Shawn
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 11-19-2013, 11:26 AM   #7
70CHEVYBB
70CHEVYBB's Avatar
I would like to convert to a cable but my truck is finished. I would not be able to weld to the firewall. How is everyone converting there gas pedal?
70CHEVYBB is offline   Reply With Quote
Old 11-19-2013, 12:35 PM   #8
bbcmudtruck
I bought a 72 gas pedal assembly from the forums and then bought an LFD adapter for it. I haven't had the chance to install it yet, however through reading through all the forums, all I need now is a throttle cable. Since I'm swapping out my sbc to a bbc, I'm kind of wanting to wait on ordering the Lokar cable until I know exactly what length I will need.
bbcmudtruck is offline   Reply With Quote
Old 02-17-2015, 11:31 PM   #9
SierraMtns
SierraMtns's Avatar
Did you do the conversion? I am looking at doing it too but not sue LFD is still making the adapters.
SierraMtns is offline   Reply With Quote
Thread Tools
Display Modes
