My LS swap
Just finished up my LS swap - big difference than the inline 6 that used to power my truck.
http://i358.photobucket.com/albums/o...0/DSC02997.jpg |
Re: My LS swap
JEALOUS!!!!!!!!!!! lol i plan to do that eventually but dont have the funds at the moment, is that a truck 5.3?
70 C10 working on a LSx swap ![]() 4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol |
Re: My LS swap
it is - from a 2004 Silverado
Re: My LS swap
thats cool, i cant wait to do that to mine i was thinking bout doing the 6.0 but the 5.3 will probably be enough lol
Florida Edition
![]() ![]() Join Date: Oct 2010
Re: My LS swap
Exellent job, congrats! Looks very professional.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Re: My LS swap
Looks like it came that way from the factory.
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
Old member
Nice job on the swap. Do you have any info on how to change out the fuse box to one of these late model ones? I've seen a couple of these in our trucks and think it would be a great upgrade for them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
motor exploder
Re: My LS swap
very clean install, looks almost factory! I'll bet the truck is a LOT more fun now!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
![]() Join Date: Feb 2010
Re: My LS swap
What transmission are you running? Looks beautiful under that hood!
Posted via Mobile Device |
Re: My LS swap
Hey do you mind snapping a picture of that pretty hood latch area?
Re: My LS swap
It has the 4L60E
I'll get a picture of the latch for you Friday, when I head out to the shop. QUOTE=Woodnears;5638173]What transmission are you running? Looks beautiful under that hood! Posted via Mobile Device[/QUOTE] Posted via Mobile Device
Re: My LS swap
I'm still running my original fuse box, I believe the late model box unde te hood is just giving power to the computer/ignition.
#13 |
Re: My LS swap
I'm patiently waiting!
#14 |
![]() Join Date: May 2007
Re: My LS swap
Clean , what's the mpg
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#15 |
bbadfred
![]() Join Date: Mar 2008
Re: My LS swap
Which K&N tube (Part#)is that on the intake? It looks like you also used the stock radiator hose also? I also used the stock hoses
#16 |
Boosted Member
Re: My LS swap
Incredible job on the install. Looks just like a new truck under the hood.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#17 |
Re: My LS swap
man that is very cool... what would you say on a scale 1-10, 10 being difficult, the transplant was...
any tips or tricks
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
#18 |
Re: My LS swap
Good looking install. What did you use to put the battery on the driver's side?
#19 | |
Re: My LS swap
I can't take credit for the swap, I have a buddy that owns a shop - Van Tumblin @ Tumblin Automotive, here in Laurens. He's a Ford guy and does alot modern engine swaps into older Broncos, but he did my truck for me and did an excellent job. So, for him, I would say it wasn't too difficult - they used my existing 6 cyl mounts and just fabbed up some additional components to make them work, had to order a new set of headers as the stock exhaust wouldn't clear, and then they did all the wiring - included fabbing up that box that holds the panel.
#20 |
Re: My LS swap
They used my stock battery bracket and just transferred to the drivers side - they modified it some, but not sure what they did.
#21 |
Man of Mini-Talents
Re: My LS swap
Great job on the install. Like others have said, it looks like it was born that way.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#22 |
Re: My LS swap
Very nice, I wondered how long it would take to replace the inline.
Joe
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
#23 |
Re: My LS swap
So he used the stock silverado radiator, and hoses. Never thought it would look so good!
More pics!
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
#24 |
Rusty Nuts
Re: My LS swap
Looks really nice under the hood
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
#25 |
![]() Join Date: Apr 2008
Re: My LS swap
Nice looking truck. Very clean install. What kind of drop and tires are you running? (saw your truck on anther post.)
Thread Tools | |
Display Modes | |
