1 more ? for the day - throttle linkage for edlebrock carb with 283 and manual trans
do i need some sort of adapter or do i need to remove the metal rod linkage and replace with a cable actuated setup?
thanks again! - jason |
Re: 1 more ? for the day - throttle linkage for edlebrock carb with 283 and manual tr
sorry its a 63 c10 with factory 283 and factory 4 speed floor shift
Not sure if this helps but when I changed out my intake I upgraded my throttle linkage. I used to heim joints and a pieve of 5/16 fine threaded rod (I think). I used shoulder bolts to fasten heim joints to the carb, and throttle linkage. If this helps, I could take it apart and take more detailed pics.
Let me know!
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
I should note that my carb is a holley, and my truck is a 66, but the engine is a 283
thats awesome - thanks for the ideas!
as for the vent thing i simply pulled igt and installed a freeze plug and used valve covers with an oil filler, a breather and a pcv valve to the carb. hope that helps! |
I have a 66 that had a 2bbl/283. Dropped in a 350 with a AFB 4bbl. old style manual 4sp tranny. Used original rod and ends for the throttle linkage... Just beefed up the return spring. Works great.... so far.
mr gasket makes a aluminum bushing that fits the opening on the edelbrock throttle linkage
to correct the factory rod Posted via Mobile Device
///Relaxed Atmosphere |
No issue, it is currently serving as the PCV valve port. It is actually on the deck of the block between the distributor and the firewall. It's days are numbered though as I am about to order a 350 crate engine, just way too expensive to even think about rebuilding the 283.
Thread Tools | |
Display Modes | |
