![]() Join Date: Jan 2010
Onsite Vender for complete brake lines?
Is there a vender on the site that sells complete bent brake lines for a '85 2wd? Looked around and don't see one for the complete set.
Thanks Coater |
![]() Join Date: Sep 2010
Re: Onsite Vender for complete brake lines?
x2 same setup. Maybe stainless too
1985 c10 355 th350 (working on 4 speed conversion to super t10) 1979 camaro 358 super t10 2003 f250 superchip slp exhaust |
that makes 3. i would like a set for my diesel and my hillbilly. i think that amk?? or maybe it was some one else made them for up to 72 but i dont think i found one for the 73-87 trucks.
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
I'd like to find the hard lines that stretch across the rear axle...can only find them in the form of bulk tubing. Bleh!
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
make your own, its easy most likly cheaper
I agree.
The lines that run across the rear axle (and some other locations) were originally covered with a spiral wire wrap to protect them from stones & other debris. If you want to duplicate that on your replacements, that type of line is available from most auto parts stores. For example, NAPA #8131188 through #8131193 are straight pre-flared lengths of 3/16" armor wrapped brake line ranging in length from 12" to 60". Equivalent CarQuest numbers are 3308 (8" long) through 3360 (60" long). It's available in 1/4" too. If rust & corrosion resistance is a concern, look into using Ni-Copp or Cunifer brake line. It's a copper/nickel/iron alloy that's DOT approved for brake lines and is real easy to bend & double flare. It's a bit pricier than regular steel brake line but will last a lot longer on vehicles that are exposed to road salt. |
I used the bulk stuff and had the entire rear line replaced in less than 2 hours and it cost less than 30 bucks. The "borrowed" flare tool cost me 22 bucks initially but got that back when I returned the tool to Oriely's Auto Parts. Why would you pay more for prebent? The bending tool (I had my own, but also available on loan from Oriely's) is so easy to use and the lines are so easy to bend/tweak it's insane. Just pull the old lines off, copy them on the ground with the new materials, then install. Unless you're looking to do a pretty show-only truck, prebent is a waste.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
I bought from LMC....
1996 S-10, 17" Boyd Coddington smoothie II, lowered 5/5, 98 up front, grant step shavers, maserati deep emerald green 2002 Camaro SS, LS-1 motorsports lid, Eibach spring, Chrome ZR-1s 9/11, TEA heads, forged internals, 244/248 cam, 3400 stall, full bmr suspension, TNT F2 kit, BLA BLA BLA ![]() 74 C-10, lsx swap, bonspeed billets, full frame off build 2008 Avalanche LTZ all stock |
Inline tube, available in regular and stainless steel. They have whole vehicle kits too pretty cheap. I recently used their rear axle set for my 78 suburban and it looks just like the original with the spiral covering and fit well. Because it is stainless, I shouldn't ever have to replace it again either.
I did the whole car front to back on my MoPar, including the line lock roll control, the car has full custom brakes from Aerospace Engineeing, it was simple to do and fun too
Thread Tools | |
Display Modes | |
