Old 05-30-2003, 12:43 AM   #1
WB72
Before and After
WB72's Avatar
What to do with antenea
Should I keep the antenea in its stock position or move it some where else?
Show me some pictures of other places to mount it, or convince me to keep it there.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 05-30-2003, 04:14 AM   #2
Mudder
Mudder's Avatar
Well
I didn't want to put a hole in the cowl so I mounted mine on the bedside.
Mudder is offline   Reply With Quote
Old 05-30-2003, 04:20 AM   #3
Seke69
Space Cadet
Seke69's Avatar
I don't like the stock position, I think I'm going to mount mine where the gas filler neck is supposed to be, when I finally get around to relocating the gas tank...
Seke69 is offline   Reply With Quote
Old 05-30-2003, 06:54 AM   #4
chevykid1969
chevykid1969's Avatar
I shaved the stock hole and left the small part of the antenea ununder the cowl, looks good and the radio still works great.
chevykid1969 is offline   Reply With Quote
Old 05-30-2003, 07:01 AM   #5
ZOOMY
windshield antennas
Are windshield antennas available for our year trucks ?
ZOOMY is offline   Reply With Quote
Old 05-30-2003, 07:16 AM   #6
Andy4639
Old member
Andy4639's Avatar
Cool Frenched, Oh NOT suppose to use that word
I installed mine behind the passenger door. Works great.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-30-2003, 08:17 AM   #7
Jwill41
Jwill41's Avatar
I have mine strapped under the dash on my 68. Works good and is not seen at all.
I have it mounted to the back of the cab on my 67 in this picture.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 05-30-2003, 10:12 AM   #8
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
dido on the rear windshield antenna!
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 05-30-2003, 10:13 AM   #9
WB72
Before and After
WB72's Avatar
I think that I'll try to hide it, I don't listen to the radio much anyway, ucually CD's. If I do need the antenea, I could always put it anywhere later.
66,000 miles.
Alberta, CANADA
Old 05-30-2003, 10:42 AM   #10
landon4421
Life is Good !
landon4421's Avatar
When I get to the cab part of the restore I am putting mine in the hole on the cab for the fuel filler neck. Like Andy4639, has his done.:p
On Jenna's 71 the antenea is still in the cowl, we don't use it that much we put a satellite radio in the truck. No commercials, and lots of choices.
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 05-31-2003, 07:51 AM   #11
OhioDan
OhioDan's Avatar
Radio Shack sell an antenna that is goes around the inside of your windshield. A friend had one in his truck, and swears it's better than stock. Have to work with it a little to hide it, but it's almost invisible from the outside. My $.02.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 05-31-2003, 09:47 AM   #12
slam33
slam33's Avatar
I did a hide a way antanna, got it for aviation/boats. Stuck it under the wiper cowl and filled the antanna hole. works great.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 05-31-2003, 09:00 PM   #13
cruzn72
You can leave the antenea off all together and listen to the music from your engine. After putting a stall and 4:11 gears in my truck the radio would have been a waste.
http://photos.yahoo.com/cruzn72@pacbell.net
cruzn72 is offline   Reply With Quote
Thread Tools
Display Modes
