Old 10-13-2012, 08:28 PM   #1
fatgump
fatgump's Avatar
Need some help with steering
My steering is binding. Besides the angles does anyone see anything that I am doing wrong? The two on top are mine, the rest are what some people are running and not having issues.
I would prefer to not buy another steering column since the one I have is new. Any help is appreciated.
fatgump is offline   Reply With Quote
Old 10-15-2012, 07:50 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Need some help with steering
Who's front end are you using?
Any way you can pull the column up inside the cab more, to lessen the angle of your steering joints?
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 10-15-2012, 06:06 PM   #3
fatgump
fatgump's Avatar
Thanks for your response. I tried tha
t. It seems I will be buying a different column.
Old 10-15-2012, 06:40 PM   #4
PBFAB.COM
PBFAB.COM's Avatar
Can you tell where it binds?
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-15-2012, 06:43 PM   #5
Scottshotrods
On your middle u-joint you have on the frame you can trim some off the edge of the frame rail and this will allow for a better angle on the u-joint.
Justin
Scottshotrods is offline   Reply With Quote
Old 10-18-2012, 09:58 PM   #6
fatgump
fatgump's Avatar
I pulled the column up to the linkage and tried. It did not work.
I cant tell.
Justin
I did take a little off the frame to maximize clearance. I cant do anymore due to the a-arms.
Thank you for the suggestions. Does anyone know how much a custom column from ididit will cost and what there lead time is?
Old 10-18-2012, 10:28 PM   #7
Scottshotrods
We are a stocking Dealer for Ididit.Most columns you can have in 5 working days.
What kind of finish do you want on the column.
1.Steel Raw
2.Chrome
3.Black powder coated
4.Column shifter or tilt only
We have some of the best prices on ididit columns out there.You can call us on friday at the shop and we will take care of you for sure.Give you a price you cannot pass up!!!!
You can reach us at (805)485-0382
Justin
Old 10-19-2012, 12:06 AM   #8
Portmod7
Portmod7's Avatar
Its hard to see the angle, but have you tried or would it be possible to shorten the shaft going down through the heim to the rack, and lengthen the one above?
I can't tell if there's room for the joint above the control arm mount to move down closer to the heim or not... I am also not sure if it would lessen the angle off the column, if i had to guess from the picture that's where I would say the problem is. Hard to tell.
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
Thread Tools
Display Modes
