10-17-2012, 04:50 PM | #1 |
Cool Truck
Trailer harness
I wanted to hook up a trailer harness on my truck and was wondering if anyone has ever used the one from LMC? Have you had any problems with it, and how do you go about installing it?
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=50
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
10-17-2012, 06:46 PM | #2 |
Old member
Re: Trailer harness
U can pick those up at local trailer shops also. There is a rubber connection at the last support under the truck where the rear harness can be unplugged from the rest of the truck. Take that connection loose and the end going up front plug the insirt adapter into it and then the rear harness into it. Your done.
10-17-2012, 08:16 PM | #3 |
Cool Truck
Re: Trailer harness
what do you mean by last support under the truck?
10-17-2012, 08:21 PM | #4 |
Old member
Re: Trailer harness
Look under the truck at back drivers side. The frame rail there should be a brace going over to the passenger side. There should be a rubber gormlet right there close that pulls a part. It should be tucked up in the frame with a clip.
10-17-2012, 08:27 PM | #5 |
Cool Truck
Re: Trailer harness
ok, thanks for the info
10-17-2012, 09:01 PM | #6 |
Old member
Re: Trailer harness
Your welcome!
Thread Tools | |
Display Modes | |
