10-18-2012, 09:47 AM | #1 |
gas tank sending unit help
im building a 72c10 that originally had three speed column but im going with th350. there are two different sending units difference being auto or manual trans. im using the original tank and gauge so which one should i get. also installing painless wiring. any help would be appreciated.
10-18-2012, 09:57 AM | #2 |
Re: gas tank sending unit help
I've never heard of a specific gas tank sending unit for a specific trans, the sending unit should be the same no matter what transmission you have.
http://smg.photobucket.com/albums/v655/aaronhero/ |
10-18-2012, 10:00 AM | #3 |
I read once it is the resister on the back of the gauge one can change out. Must be for different tanks not trannies.
My fuel cell when full only reads 1/4 tank on the gauge, so I was wondering about this too....
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
10-18-2012, 10:45 AM | #4 |
i was looking at the sending units at brotherstrucks.com. they list the different units.
10-18-2012, 11:19 AM | #5 |
If is isn't reading correctly, it could be the wrong unit for the tank. Also if it has a brass float there may be a tiny pin hole allowing gas into the float so it doesn't rise as high as it should. I bought one of these floats for mine and it works great so far.
http://www.ebay.com/itm/65-66-67-68-...r#ht_500wt_922 As far as there being different sending units for manual vs auto tranny, I am not familiar with that.
How 'Bout them Dawgs! '10 Traverse LTZ 03 Silverado Z71 ext cab 99 Yamaha Grizzly 600 72 C10 350/350 sportside bed. 68 C30 flatbed. 350 4-speed. "I've got a good memory, it's just short!" |
10-18-2012, 01:31 PM | #6 |
The fuel cells have three choices and I guessed at the first one.
summit racings different sensors: 0 empty-90ohms full 233 empty- 30 ohms full 70 empty -10 ohms full
10-18-2012, 01:34 PM | #7 |
mine was 0-90 ohms for the in cab tank but now I am getting a stainless cell built for under the bed anyone know if I would use the same rating unit?
10-18-2012, 11:29 PM | #8 |
"Ochre Ogre"
Del72, You would need the 0-90. Your gauge is an analog ohm meter. It doesn't matter what tank, only what ohm range it reads.
My suppliers parts book shows a 72 auto has 2 outlets and a 72 with manual has only one fuel outlet on the sending unit. 71 and older are the same either way, only 6 cylinder vs 8 cylinder options.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
10-19-2012, 12:04 PM | #9 |
thanks for the info..
10-19-2012, 03:08 PM | #10 |
Cool...it must be my ground wire, have to re wire her..
Thread Tools | |
Display Modes | |
