Ignition lock cylinder
My lock cylinder is just spinning with the bezel. How to I remove the cylinder with out the bezel wanting to spin with it
72 Chevy lwb, ps, pb, 355, big cam, th350, tach, posi, leaf rear 04 Ford F-250 6.0 powerstroke crew cab long bed, MBRP 4 in. Straight pipe, ARP headstuds, sinister diesel coolant filter 97 Ford F-350 7.3 powerstroke 4x4 crew cab long bed 5 speed, stage 1 injectors, straight pipe, 250,xxx miles and running strong |
#2 | |
The Older Generation
Re: Ignition lock cylinder
LockDoc
Yes I do I've tried the paper clip trick but it still spins when I turn it
#4 | |
LockDoc
It's screwed in but when you turn the key the entire lock and bezel spins
#6 | |
Read through this thread if you haven't already. http://67-72chevytrucks.com/vboard/s...d.php?t=462981 LockDoc
Reach under the dash and hold the ignition&try the paper clip method once again should work just stay with it. hope this helps you. cheers, Pat
Got it fixed thanks guys
Thread Tools | |
Display Modes | |
