14 bolt question
How do you tell the difference in a full floater or semi floater?
1969 chevy camaro Z28 #matchin Factory 4wheel disc 1969 chevy cst10 big block overdrive 5/7 drop dog dishs 1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s 2004 gmc sierra dually 4/4 lowering daily driver |
Re: 14 bolt question
Full floater has axles that bolt to the hub from the outside. Semi the axles go in like a 1/2 ton.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
A full floater that I'm aware of has a very distinctive hub where the axle flange actually bolts in from the outside, and the drum assembly rides on a set of bearings, hence a floating axle. Will also have an 8 lug setup and rather large drums. At least my 1 ton 14 bolt does.
I'm not totally familiar with the semi float 14 bolt but I believe it wouldn't have any of the features I listed above, smaller brakes/drums, and the axle actually rides on a bearing like a conventional rear and uses C-clips to retain it. The ones I've seen have also been 6 lug, but may not always be. |
Mines a 8 lug but i don't know if it's a c20 or 30. Anyway to tell that? It's In a crew cab but I think the PO said the rear end was out of a 3/4 suburban
so this would be a full right?
Yup.
full floater = 8 lug
semi-floater = 5 or 6 lugs You can find a 14 bolt semi- floater in the 454SS pickups. RIZ |
![]() Join Date: Jun 2007
the semi floater 14 bolt [9.5"] 8 bolt is common in 80s suburbans and 3/4 pickups too. not all 8 lug are full floater. easiest way as said above is check the bolt on axles.. dead giveaway..
neat little video on full floaters |
First 2 - 14 bolt Full Float - 8 lugs Only
The full float also has a removable pinion (bolts at yoke), where as the semi-float does not.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L Last edited by Ski-me; 10-23-2012 at 02:19 PM. |
Semi-Floats can be 6 lug or 8 lug....depending on truck.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L Last edited by Ski-me; 10-23-2012 at 02:14 PM. |
Stop teasing me, I'm looking for a semi float 6 lug 14 bolt
#12 | |
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
#13 |
I want one for my K5 too. So hard to find around here. I'd love to get one and put 4:56 gears in both for my new 35's.
RIZ |
#14 |
Windy Corner of a Dirty Street
Am I due any royalties for the use of my 8 lug 9.5" semi-floater picture
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
#15 |
if i understand right the 3/4 tons are semi float and can be full float depending on year and the one tons are full float only. at lest thats how mine are. 3 one tons and 1 3/4 with the higher gvw
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
#16 | |
#17 | |
Chevys Kick A$$
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
#18 |
This might be the same video Speedmachine was trying to post. This is a great video explaining full-floating rear axles. The video is from 1936! The basic design is still the same today.
It floats
Thread Tools | |
Display Modes | |
