![]() Join Date: Dec 2011
Assistance on static drop pics/info
Need your help. Can you post you static drop pics/specs (preferably) or point me to some threads you might now of on 73-87 static drops with pics/specs. I have seen a few but nothing specific with this especially on 73-87s. Then again it could be operator error.
I am in the process of lowering my truck 85 1/2 SWB, but I wanted to see what I can expect before I install the front stuff. I bought a 4" Western Chassis hanger/shackle kit, (installed this past weekend and let me tell you it was a job easy but tedious, but thanks to my 15 yr old sons help it is done). I think the results of that will be good for the look I was after especially once the front is done. For the front I got CPP 2.5" spindles and was also contemplating cutting stock springs one full coil, but I think it might be too much or maybe just right compared to the rear thus I wanted to see what it might look like with either or. Also, if I cut the spring, (A) cut from the bottom or top? and (B) will it be ok if I cut only 1/2 of one full coil? Thanks. I will post pics of the rear drop when I get home. |
BAD BOW-Silverado XST
Re: Assistance on static drop pics/info
Checkout LMC's diagrams at http://www.lmctruck.com/icatalog/cc/full.aspx?Page=142
67-72 parts collector,
![]() Join Date: Nov 2002
http://67-72chevytrucks.com/vboard/s...hlight=lowered
thanks for the help guys.
Keith, how did you find the threads? i looked through 100 pages of the suspensions section, i used the search option with plenty of key words? i knew it was operator error. here are a few pics to see what you guys think in terms of cutting my coils. i do want a little bit of rake. |
#5 | |
Many of them. I just picked the two with the most threads,... located in the 73-87 section. Use the search box there. When you cut your front coils remember: 1/2 coil cut= one inch of drop. (approximately)
So i can cut 1/2 a loop? and do i cut from the bottom or top? thanks.
#7 | |
There is no left or right spring. They are the same even though you are placing them in left and right a-arms. I always cut from the bottom. Then you can still "clock" the upper spring loop in the "D" shaped bracket in the upper spring pocket.
Are your front tires going to clear the fenders after you lower it more?
^^^ I think they should. You mean from top to fender lip? I have not lowered the front any yet.
Posted via Mobile Device |
#10 | |
(as in too wide or wrong offset wheel)
#13 |
Cruzzzn' Vet
What size tire you running on the front, look like a 255/275-60, if you cut the coils your looking at a 2" drop for every complete coil you cut, and yes cut from the bottom, looking at the pictures you tires will rub if you go lower on the front, this is my 83 that was lowered by cutting 2 coils on the front, i'm running 245-60-15's on the front with 15x9 rims. With your 2.5 spindles and cutting 1 coil you should come out with a 4.5 drop on the front, and with a smaller tire you should get the stance your looking for with no rubbing
![]() ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us |
#14 |
I think I would install the spindles and take a look at it. I know it seems like a lot of work, but at least then you will have a good idea on where you want it. Besides if you cut the spring and you don't like it, you're only choice is to buy a new set of springs. Good looking truck!
"Whoever said money can't buy happiness has obviously never seen a speed shop! |
#15 |
First Picture: Stock Height
Second Picture: 4" hangers/shackles with 3" drop spindles Third Picture: added 2" drop coils to the front
1993 ![]() 2007 Chevy Silverado 1500 Crew Cab LTZ 4x4 1974 AMC Matador Coupe - The Mat |
#16 | |
[quote]
i am running 255/70s on the 8"ers. thanks for the pics. you did a flip in the rear? |
#17 | |
another reason i wanted to cut some of the coils is because i have the lean by about an inch on the drivers side so, we'll see. thanks. |
#18 | |
your truck seems to have come down more from the back after you installed the rears. did it. because i was thinking mine might come down more on the rear when i do the spindles, but don know maybe its just the picture angle or higth. thanks for you help. |
#19 | |
#20 | |
i thought about that especially for my lean issue. i wonder if new ones might correct it. thanks. |
#21 |
They ride fine, what ever brand Brothers catalog sells?
#22 | |
Cruzzzn' Vet
[quote=Lost81c10;5676883]
#23 |
I have a 5/6 drop on 8" ralleys with a flip kit (all western chassis parts). The front consist of 2.5 drop spindles and 2.5 drop coils. Since evevy cut coil gives you 2 inches. I would suggest starting with half a coil (1" added drop to you 2.5" spindles), and see how it sits. If you're still not satisfied with the stance, chop another half coil which gives you the full 2" drop on you 2.5 spindles leaving you with 4.5 in the front. Any additional lowering(Unlikely)- I would reccomend buying drop coils for ride quality.
BLUE SQUARE |
#24 | |
#25 | |
http://www.73-87.com/7387garage/chas...n/frontend.htm it came from here. you might want to check all the other articles to give you an idea: http://www.73-87.com/7387garage/gara...suspension.htm |
Thread Tools | |
Display Modes | |
