06-01-2003, 03:26 PM | #1 |
327: Small or Large Journal
Buddy of mine gave me a 327 all machined with 4-over pistons, 2-under crank. (Yep, for free :-) Need to get rings and bearings for it.
Anybody know exactly how to tell if it's a small or large journal engine? David
1972 Chevy Cheyenne Super LWB Chevy Red/White with rally wheels. Not-so-Stock 350, A/T, A/C, tilt. Vroom, Vroom.... ===================== David Colbert dcolbert@twcny.rr.com Work hard, play harder! |
06-01-2003, 04:17 PM | #2 |
Registered Cruiser
I'm not positive but I beleive that the small journal engines had pressed on vibration dampers, and the large journals are bolted on.
I intend to live forever. So far, so good. |
06-01-2003, 06:06 PM | #3 |
You could look up the suffix code at nastyz28.com and if its a 68 block its large journal.. everything older is small journal.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
06-01-2003, 06:17 PM | #4 |
Small journal cranks have 2.3 inch mains and 2 inch rod journals. Large journal cranks have 2.45 inch mains and 2.1 inch rod journals. and jhhwks is right most large journal cranks have the nose drilled for a balancer retention bolt.
06-01-2003, 06:22 PM | #5 |
Fabricate till you "puke"
the quickest way to tell at a glance......the rear flange(that the flywheel bolts to), is round(machined) with 2 notches cut out on the SJ crank. The LJ crank has a more oblong shape on the rear flange(like a little counterweight added). crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-02-2003, 08:29 AM | #6 |
You guys are awesome. Thanks!
Turns out to be a large journal engine. David
Thread Tools | |
Display Modes | |
