Old 11-03-2012, 08:59 PM   #1
shawno72
C/10 junkie
shawno72's Avatar
Where do you mount the spare tire carrier?
I have a 68 swb fleet that didn't come with a spare or spare tire carrier. I recently got one but which holes do you hang it from under the frame? Pics would be great. Thank you.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 11-03-2012, 11:11 PM   #2
Jurassic-1
Jurassic-1's Avatar
Re: Where do you mount the spare tire carrier?
The left frame rail has a hole in the center of the rail directly behind the panhard bar mount. The bolt goes through it and has a upper and lower nut. The upper and lower nut allows adjustment for wheel thickness. The other side has a hole in the right rail near the back at about the front bolt hole on the right rear bumper bracket.This is the long bolt that is threaded near the end. The bed may have to be lifted to get it in due to the fact that it is put in from the top.I have cheated and slightly bent the bolt to allow it to feed through the hole without removing the bed. After it is in you can bend it back straight.
Jurassic-1 is offline   Reply With Quote
Old 11-03-2012, 11:25 PM   #3
shawno72
C/10 junkie
shawno72's Avatar
Sounds easy enough. Got any pics? Thanks for the info.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 11-03-2012, 11:57 PM   #4
Malamute
Malamute's Avatar
Not to hijack but as an aside.....my truck has the spare and carrier mounted but when I drop the truck am I going to have issues? Planning on a 4/6 drop fwiw.
Malamute is offline   Reply With Quote
Old 11-04-2012, 12:17 AM   #5
Jurassic-1
Jurassic-1's Avatar
You can always get the stock bracket to mount it in the bed in front of the wheel wells .It can go on either side. They look ok on some trucks and you can put a stock hubcap on after it is bolted in. Or option 2 mount it lying down with a cover on it.
Old 11-04-2012, 12:17 AM   #6
Jurassic-1
Jurassic-1's Avatar
I can get some tomorrow.
Old 11-04-2012, 01:40 AM   #7
diabloceto
I have an ECE 4/6 drop on my truck and have my spare tire back there no problems. It will be coming off though when I put a gas tank back there.
Diabloceto
diabloceto is offline   Reply With Quote
Old 11-04-2012, 02:04 AM   #8
Malamute
Malamute's Avatar
Diabloceto
Thanks, I'll plan on leaving it.
Old 11-04-2012, 11:31 AM   #9
Jurassic-1
Jurassic-1's Avatar
Here are pictures of the tire rack. I have a hitch so the right side has a home made bracket. It would normally be the hole in the rear of the frame rail on a short bed.
Old 11-04-2012, 11:37 AM   #10
shawno72
C/10 junkie
shawno72's Avatar
Cool thanks so much
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 01-15-2013, 05:52 PM   #11
Madtat
Madtat's Avatar
This thread helped me. Thank you posters.
Madtat is offline   Reply With Quote
Old 01-16-2013, 01:43 PM   #12
shawno72
C/10 junkie
shawno72's Avatar
That's the beauty of this forum. There's a ton of info.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Thread Tools
Display Modes
