Old 11-05-2012, 10:52 PM   #1
Malamute
Malamute's Avatar
Replacing starter....questions
I've searched and haven't found the specific info I need.
First of all over the last few weeks the starter labored more and more when starting my truck. Finally it just got to the point it made a grinding sound and then just quit. Don't think it's the solenoid and the battery is new.
I pulled the starter tonight(what a PITA that was with the headers next to it). I had to drop the starter first to even get to the point I could remove the wires and in doing so the connector came off of the wire on the R post. I can strip the wire and get the connector back on, that shouldn't be a problem.
I'm going to get the starter checked in the next few days, if it's bad I think I'm going to replace it with a smaller high torque starter. #1, is the wiring the same for these and #2, will it need to have the shims placed the same as the starter I'm replacing?
I know, long winded but I ran into a few problems I didn't plan on. Thanks.
Malamute is offline   Reply With Quote
Old 11-05-2012, 11:36 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: Replacing starter....questions
Yes on all accounts. The mini starter at O-Reilly's auto parts is a great starter and it's a stock iteam also.
Mine is over 3 years old and hasn't missed a start yet!
http://67-72chevytrucks.com/vboard/s....php?p=4151565
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-06-2012, 05:09 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'd be concerned about the newer starter having the small terminal for the yellow wire if the original poster still has points type ignition. It's a non issue if he has HEI of course.
Old 11-06-2012, 07:46 AM   #4
chevy72pu
chevy72pu's Avatar
Here is the one I used. All wires connected just like the old one. Used one shim and it's a lock. 350 engine.
http://www.dbelectrical.com/p-1319-n...sdr0031-l.aspx
How 'Bout them Dawgs!
'10 Traverse LTZ
03 Silverado Z71 ext cab
99 Yamaha Grizzly 600
72 C10 350/350 sportside bed.
68 C30 flatbed. 350 4-speed.
"I've got a good memory, it's just short!"
chevy72pu is offline   Reply With Quote
Old 11-06-2012, 11:02 AM   #5
Malamute
Malamute's Avatar
Still have point, had both wires but I just need to crimp a new connector on the end of one of them. Maybe I'll go with something like chevy72pu posted.
Thanks for the replies.
Old 11-06-2012, 11:02 AM   #6
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Originally Posted by chevy72pu View Post
here is the one i used. All wires connected just like the old one. Used one shim and it's a lock. 350 engine.
2x
TobyArnot is offline   Reply With Quote
Old 11-06-2012, 11:03 AM   #7
GMCJOE
GMCJOE's Avatar
I currently am using a starter off of a 98 or 99 Tahoe. It is the same as a mini-starter. I picked mine up from the salvage yard, the Tahoe was wreck and the unknown was there. The solenoid must have got a pretty good jolt. It pulls power and drains my battery in the ignition off position. With this said, I would not go that route (salvage yard) unless they let you take it to Auto-Zone to get it tested before purchasing it. I paid $25 for mine, so I could fix it or just toss it for a new one.
Mine looks just like the link Chevy72pu posted up. That's a good price too. That will probably be my replacement also.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 11-06-2012, 11:28 AM   #8
cdowns
cdowns's Avatar
i would have cleaned up all 4ends of the plus and neg battery cables and where they mounted prior to removing and replacing the starter
Old 11-06-2012, 04:19 PM   #9
Malamute
Malamute's Avatar
I don't think it was the connection but I thought about that. The starter was grinding/binding and then it just stopped altogether. Headers next to the starter make it fun to get to as well. That's why I'd like to get a smaller motor for when it goes back in, it really was a tough reach.
Old 11-06-2012, 06:03 PM   #10
arocars
A heat shield is a good idea if your headers are really close to your starter. Also, not all mini starters are created equal. I bought an inexpensive one and it failed due to heat right away. I bought an expensive race starter and never had another issue.
arocars is offline   Reply With Quote
Old 11-06-2012, 10:53 PM   #11
oklalawnboy
oklalawnboy's Avatar
Originally Posted by TobyArnot View Post
2x
X3 but be sure you use the new bolts. They are metric diameter with standard threads. With reg/old type starter bolts, it can walk around a bit.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 11-07-2012, 12:22 AM   #12
Malamute
Malamute's Avatar
Thanks for all of the input. I'll take it in Friday to see if it's actually the starter and I'll probably go with the O'Reilly if it is.
Thread Tools
Display Modes
