Old 11-06-2012, 01:14 AM   #1
mexlokote
mexlokote's Avatar
overheating
i have an 82 c10 original inline 6,
currently overheating it stays cold for like 15minutes then heats up really fast,
currently have a very very small leak on the waterpump, maybe thats causing
to overheat i dnt know,
what causes my engine to overheat has brandnew failsafe thermostat
mexlokote is offline   Reply With Quote
Old 11-06-2012, 01:25 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: overheating
Enough water?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-06-2012, 01:28 AM   #3
mexlokote
mexlokote's Avatar
Re: overheating
its full the wierd thing is that whenever i turn the engine on and squezze the upper hose that goes
from the radiator to thermostat doesnt have any preassure like it dnt have water in
Old 11-06-2012, 01:33 AM   #4
INSIDIOUS '86
Re: overheating
When the engine is cold and at idle pull the rad cap and full with water. Do you have a water temp gauge as well?
Old 11-06-2012, 03:18 AM   #5
Skunksmash
Skunksmash's Avatar
Re: overheating
Sounds like you got air in there and you need to burp the system. Park the truck on some kind of incline, like ramps or something, and take the radiator cap off. Start it and let it run to its normal operating temperature. Let it run that way for a while. If its got air in there you'll see the radiator bubbling and gushing as the air escapes. Once its done just add more and its fixed. If indeed your problem was air in the system.
Skunksmash is offline   Reply With Quote
Old 11-06-2012, 08:40 AM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: overheating
if the waterpump is leaking best to change it and thrw a thermostat while youre at it then add proper fluid and burp then the thing is properly fixed
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-06-2012, 01:51 PM   #7
mexlokote
mexlokote's Avatar
Re: overheating
thanks i will try that
Old 11-07-2012, 11:36 AM   #8
MDc10
MDc10's Avatar
Re: overheating
Don't know if you have a electric water pump or not. There is a way that they can run backwards, I don't know if it's possible on the others. I've seen it before, had a buddy and his ride was overheating and couldn't find out why, come to find out it was running backwards.
MDc10 is offline   Reply With Quote
Old 11-07-2012, 11:39 AM   #9
mexlokote
mexlokote's Avatar
Re: overheating
its not electric
Old 11-07-2012, 01:29 PM   #10
INSIDIOUS '86
Re: overheating
What's the temp getting to?
Old 11-07-2012, 01:34 PM   #11
mexlokote
mexlokote's Avatar
Re: overheating
np idea the guege doesnt move from cold, how dp i fix that?, the ground on my gas tank is not connected
Old 11-07-2012, 03:41 PM   #12
RastaRobb
RastaRobb's Avatar
Re: overheating
If that leak is coming from the weep hole (top of the pump) you can know for sure the pump is pooping out on you, and will need to be replaced. New stat never hurts while your there.
RastaRobb is offline   Reply With Quote
Old 11-07-2012, 03:52 PM   #13
mexlokote
mexlokote's Avatar
Re: overheating
the leak is at the top of the pump
Old 11-07-2012, 04:32 PM   #14
tucsonjwt
Re: overheating
If your water pump is leaking then it needs to be replaced (along with thermostat as suggested above.) I recommend getting an AC Delco pump from one of the OEM online vendors,( since it is a bit of a PITA to work on you only want to do it once.) Before you start the surgery, also make sure that you fan clutch is working properly - go with Delco on that also.
If you google the usual suspects you can often find a discount coupon for those OEM vendors. I have used all of the following with good results:
AutoPartsTomorrow.com
oewarehouse.com
oehq.com
gmpartsdirect.com
rockauto.com
Also, just google the OEM part number (you can get that from the Rock Auto online catalog) and see if any good deals turn up on other sites (like Amazon, Ebay, etc.) Delco parts can often be purchased for less cost than good brand aftermarket parts.
tucsonjwt is offline   Reply With Quote
Old 11-07-2012, 04:48 PM   #15
mexlokote
mexlokote's Avatar
Re: overheating
great info thanks!
Old 11-07-2012, 04:51 PM   #16
RastaRobb
RastaRobb's Avatar
Re: overheating
Yeah, sounds like a pump for sure. I have a great luck recently with several rockauto parts. If your not in a hurry and can wait for the shipping, the price is much better.
Old 11-07-2012, 04:54 PM   #17
mexlokote
mexlokote's Avatar
Re: overheating
i have ordered a haynes menual at rock auto shopping was only 2 days
Old 11-07-2012, 06:05 PM   #18
Skunksmash
Skunksmash's Avatar
Re: overheating
The factory gauges are junk get aftermarket with new sender and wire imo.
On two different trucks (one an 82, and one an 87) the stock gauge was over 30 degrees off from reality. You can't trust that stock gauge. And with your overheating problem, you need to be sure.
Or if you can't do all that right now, at least get this. Point it at the water neck. (the thermostat housing thing)
CE Compass Temperature Gun Infrared Thermometer... CE Compass Temperature Gun Infrared Thermometer...
Old 11-07-2012, 07:44 PM   #19
mexlokote
mexlokote's Avatar
Re: overheating
so today i tried to get the waterpump out but before i thouched any bolts, i found out the leak is coming from the waterneck the thermostat housing, so i pulled that out, it didnt had gasket it had like somekind of red siliccone, so tomorrow i will get a new gasket,
Old 11-07-2012, 07:44 PM   #20
mexlokote
mexlokote's Avatar
Re: overheating
sorry picture upside down
Thread Tools
Display Modes
