Old 06-01-2003, 11:24 PM   #1
Mudder
Mudder's Avatar
stereo/electric/ problem?
Got a small pop in my stereo when I apply my brakes. Now its doing it when I turn the turn signal on. I thought it was the brake light switch but it has me scratching my head now. Bad ground somewhere?
Mudder is offline   Reply With Quote
Old 06-01-2003, 11:32 PM   #2
RAT-AT-TACH
RAT-AT-TACH's Avatar
where did you run your main power too?and where is your acc hooked up?
on most stereos the antenna will act as a solid ground.
RAT-AT-TACH is offline   Reply With Quote
Old 06-01-2003, 11:33 PM   #3
Mudder
Mudder's Avatar
all the power supplys are to the battery
Old 06-01-2003, 11:33 PM   #4
pissonNOS
senior member
pissonNOS's Avatar
is your battery cable touching the manifold bolts mine was and thats what was causing the noise in my stereo also try jiggling the wires behind where your keys go works for me
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 06-01-2003, 11:52 PM   #5
jef5150
Inline 69
jef5150's Avatar
dont hook up your power wire to any fuse that powers an accesory,youll get "bleed through" from that accessory,,,,,,you didnt say if it was a stock radio,or an aftermarket,they have 2 power wires,1 red ,1 pink,for channel memory
jef5150 is offline   Reply With Quote
Old 06-01-2003, 11:58 PM   #6
jef5150
Inline 69
jef5150's Avatar
are you running high power amps?......you could be getting bleed through from these also,,,you could always go to radioshack an buy a couple of noise suppresors
Old 06-02-2003, 12:01 AM   #7
Stano
Stano's Avatar
Mudder, I used to have a 79 that did that. I used a noise suppresor and it solved it immediatly.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
Old 06-02-2003, 12:13 AM   #8
Mudder
Mudder's Avatar
its all after market and yes i have high powered amps. you cant actually hear it when the sound is up but only when its between songs or the volume is down.
Old 06-02-2003, 01:27 AM   #9
Chevy Wrench
former desert rat
Chevy Wrench's Avatar
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
Sounds like either a bad ground on the amps, or maybe your RCA cables (or speaker wires) are close to your main wiring harness? I would check to see if any of them are sitting over, or zip-tied to your steering colum. Just a thought without hearing it.
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const.
Chevy Wrench is offline   Reply With Quote
Old 06-02-2003, 01:31 AM   #10
Chevy Wrench
former desert rat
One more thought, it could be an electrical spike. See if it does the same thing when you turn on your headlights. If it does, then you need a larger gauge power wire for your amps. Im running 1/0 gauge from the battery into a 150 amp fuse, then to a couple of circuit breakers at the amps.
Thread Tools
Display Modes
