Old 11-06-2012, 05:49 PM   #1
73c201
dual fuel tank hose routing
Hi I have a 1973 Chev C20 with dual tanks, it had a manual valve on the floor when I bought it and a fibreglass tank on one side, i have converted the tank to a steel factory type and have some electric parts from a 1976 and want to convert the 1973 to the electric type and wondering if anyone has a line routing diagram for this? (were the lines all rubber from the factory?)
thank you
73c201 is offline   Reply With Quote
Old 11-06-2012, 06:25 PM   #2
bnoon
Re: dual fuel tank hose routing
The majority of the length of fuel lines are steel with a few inches of rubber to connect to the junction at the switching unit and to the tank. At least on my '86.
For wiring I found this apparently for an '85
For the hoses it depends on which switching unit you're going with. The 3 port aftermarket ones I've seen only switch the feed side with no return ports being switched from tank to tank (I assume they'd just T-the returns to both tanks). The factory one on my '86 has 6 ports and switches the return line along with the feed from both tanks (two lines to the front, two lines left tank, two lines right tank). I'm not sure how you could do the 3 port one otherwise the return fuel flow would go to both tanks, at least in my mind. Not sure how that works or if it's even a problem to worry about.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 11-06-2012, 06:53 PM   #3
73c201
thank you
also need the routing of the fuel lines- i am pretty sure the 1976 is the factory one-should i check it and see how many ports it has?
Old 11-06-2012, 07:05 PM   #4
hatzie
Moderator
hatzie's Avatar
That's the wiring diagram for the later motorized 1982-1986 system.
You can find the 1973 hose routing in Section 8 of the ST330-73 1973 Service Manual. It's around 45meg.
The 1973 Wiring Diagrams are around 7 meg.
ST_330_73_1973_Light_Truck_Service_Manual.pdf
X_7305_1973_GMC_Truck_Wiring_Manual_CK_10_30_Pgs_Only.pdf
ST_333_73_1973_Chevrolet_Passenger_Car_and_Light_Truck_Overhaul_Manual.pdf
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 11-07-2012, 11:02 AM   #5
Tucson38
What's the story with that manual valve? Was it a factory item or part of the fiberglass tank? I'd prefer a manual valve to the trouble-prone electric one.
Tucson38 is offline   Reply With Quote
Old 11-07-2012, 11:37 AM   #6
Firebirdjones
Frankly I've never seen the manual valve and since the OP's added tank was also plastic, it sounds to me like it was all added at some point and not OEM. Might find some of your manual switches on bigger rigs though, but I wouldn't think so on a pedestrian truck.
I've never had any trouble with the factory electric setup on my 79. It's all still original 1979 issue and works like a champ. Although I do like the idea of the manual operation to simplify things.
Firebirdjones is offline   Reply With Quote
Old 11-07-2012, 02:32 PM   #7
hatzie
Moderator
hatzie's Avatar
The only real trouble I've seen with these is the dash switch and once in a while the valve. The problems I've encountered with the rest of the system are from "repairs".
Old 11-07-2012, 02:45 PM   #8
73c201
i don't think the fibreglass tank had a sender in it, but i just gave it away when i switched to the metal one,i know it was a huge tank- that was way back in 1983 or such when i first bought the truck, the valve was mounted on the floor just to the left of the seat. i could try and find it and send you a picture or something-- just got back around to trying to hook it up correctly. as i just found these parts from a 1976
Old 11-07-2012, 04:22 PM   #9
73c201
thanks for the manual downloads !!!
Thread Tools
Display Modes
