Old 06-01-2003, 11:28 PM   #1
mikerph
headers
Have a 51 chevy truck with a re-built 350 small block. Needing help in picking what headers to use?? Have what I call, ram-horn manifolds on now. I have seen in several magazines where others with similar trucks have used hooker block-huggers. Any one have a suggestion? I have been looking at Patriot tight tuck headers, has anyone used these?? Wanted to make sure they fit before I order them. Thanks.
mikerph is offline   Reply With Quote
Old 06-02-2003, 06:20 PM   #2
solidaxel
solidaxel's Avatar
If you have ram horns on there now and they work if I were you I would leave them on and not worry about leaky header bolts and collector gaskets. You can take the cast iron headers and grind them smoth and have then coated they will look better and disepate the heat better.
JMTCW
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Thread Tools
Display Modes
